Introduction: Make a TV Solution Out of an Dining Table
I needed a TV solution and could not find any suitable furniture.
We had a dining table around whitch was not in use.
So what happened to it you can see here.
Step 1: Take the Table Apart
first i took everything apart
Step 2: Preparing the Parts
cutting the side parts out of one of the extra leafes.
The second extra leaf was shortened about 1cm to fit.
Where possible I used the original bolts for mounting.
Step 3: Nearly Finished
The inner sides of the side parts and the top is painted white.
Two table-legs were cut and mounted.
Next step was to drill the holes for the shelfs.
Step 4: Mounting
so it was time to see if everything fits together
Step 5: Details of the Bottom
Detailed view of the bootom.
Here you can see the cutted legs and
an extra support mounted on the bottom.
Step 6: Back of the TV Solution
On the back there are two big holes to pass through the cables.
On the side one big hole for the powercables.
Step 7: Side View
So this is the view from the side.
Here you see the powerline with an switch.
Step 8: Front View
ready for the moment.
