Make a Catapault in Class
3,593
Published
Introduction: Make a Catapault in Class
this instructable would teach you how to make your own scaled down model of a medieval weapon
this requires a3 paper,
a rubber band
loads of tape
and a skewer
Step 1: 1
get your a3
fold it along the lines in the picture and tape so you get what is in the second picture
tape the black parts one round and the sides in the 4th pic
it should be hard enough not to bend
it requires a lot of elbow grease
make six
Step 2: The Body
get one stick and half it
and stick it into another stick
do it 2 times
put another stick on like in the pic
tape securely
i mean like tape it like crap
Step 3: The Body
now put another stick on the flat side at the end
this is where your rubberband goes
see picture
Step 4: The Arm
make 2 holes on the side where it doesn't have a stick
make sure that it is as close to the middle but not penetrating the middle part which sticks up
how i did it was i used a screwdriver and make a pilot hole
then screwed a screw into the pilot hole to make it go through all the way
put a skewer through it
Step 5: The Arm
now you tightly tape a paper stick to the skewer
make sure the arm is perpendicular to the base and "bridge"
if not then you may use padding later on
this is to ensure your projectile goes up
Step 6: Finishing
take the looped runbber band and put it around the arm
tape it securely
bend the end of the arm up
pull down
load
release
repeat
    • Stick It! Contest
      Stick It! Contest
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
