Step 3Pin and cut
place the pins parallel to the edge, and cut through both layers. you will note that I have cut a bit wider than the pattern here: I will check the size on the head, then cut down even more later if necessary. remember: it's easier to cut away more later than to add more later.
remove the pattern. keep the 2 pieces next to each other, but do not pin them.
Add Comment
