Make a Non Functional Gas Mask
68,707
48
43
Posted
Introduction: Make a Non Functional Gas Mask
with some googling I found this site
http://john.curtin.edu.au/education/gasmask/index.html
and they have a tutorial on how to make a gas mak out of paper , ect. well I thought it could use some work. so I went in my workshop and found things to use!
Step 1: The Design
I found this download, that is the design layout. I first made the eye covers out of plexy glass by cutting them into squares then sanding the edges.
Step 2: Side Cylinders
I used 3" pvc for thesejust cut the m to the size desired. for the middle I used a 2" pvc end cap and just drilled holes in it. then I made a plexy circle the size of the 3" pvc and drilled holes in them. on the other side of the cylinder another circle piece of plexy just with a large hole so the 1 1/2" pvc will fit and slide in then I just glued every thing together to make 1 piece.
Step 3: Put It Together
in order for the cylinders to fit on the middle piece you need to grind/ cut off some pieces (see picture. after you do that take out you hot glue gun and glue the 2 side piece to the middle piece
Step 4: Glue, Glue, and More Glue
for the face part I used an old plastic ball the kind you would find at wallmart in the tall racks in the toy section. then just cut to the design on the download. then I gleu the mouth hole to the middle piece of the pvc build.
Step 5: Finishing Up
I used large red rubber bands to hold the mask on my face. here is My end results. I will remake the face part and I will update!! now go join the umbrella corporation!!!
    • Spotless Contest
      Spotless Contest
    • Science of Cooking
      Science of Cooking
    • Microcontroller Contest
    44 Comments
    i might try this for my Halloween coustume, i going to be "mother war" from my chemical romance's concept album the black parade.
    ummm it looks nice, jk at least u tried your best
    I agree, no negativity... but unless this was made on the fly.... it could use alot of work... but don't give up!!!!!!!! because the sun will always shine tomorrow, and everyday is a brand new day!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! :')
    I'm just wondering.. are you capable of cutting circles? I don't wanna be mean but.. seriously... remake this....
    I put the mouth part in front of my paint ball mask (its not together, 2 pieces) but this would look cool on the "field" I think I'm going to pick up a airsoft mask for $10 and glue it to the mask. examples of mask below
    hey i did that a while back though mine didn't look near as good as yours
    For 15 bucks you can get a FUNCTIONAL army surplus mask, and paint it black if it is not and you so desire. I have modded a few gas masks in my time, for...eh...smoking stuff.
    If you weld wear a gas mask. Even if you have a huge fan you still inhale stuff that should never be inhaled.
    words of wisdom...... yeah.. er.. um ...smoking stuff!!
