make a self-watering planter using recycled materials on the cheap by calskin
the intro
My office manager buys jugs of water from Safeway for our water cooler.  Later I found out that these particular jugs have no deposit on those water jugs, so they're just getting thrown out instead of being reused.  I thought this was kind of silly, so I asked if I could take the jugs with me.
I wasn’t sure what I would do with them at first, but then I saw this video by Kirsten Dirksen showing a dude from Refarm the city and for about 20 seconds at 12:20 in that video, the dude shows what I’ve built here.
I recommend that anyone who’s interested in using arduino in their garden check out that video and site.  It’s all open source.  I also recommend that anyone who is interested in small homes, and very incredible ideas for sustainable lifestyles check out Kirsten Dirksen’s youtube channel.  I believe I’ve seen everything she has posted and I have had my mind blown by almost every one.
anyway
In this instructable, I will show you how to create a self-watering planter using recycled materials that are very easy to find (at least for me they are and hopefully they are for you too).
The design is self watering because you have a resevoir of water on the bottom, which feeds up to your potted plant using the power of whicking!
you will need
2 water jugs - possibly free
2 zip ties/tie straps - go to the dollar store!  They're somewhere around a dollar there.
1 old sock - free
some potting soil/compost/loam/whatever you like to plant in - possibly free
filtered water - no more than $5, but possibly free
Step 1: Lovin' the jugs
As I mentioned before, I have an advantage in this because my office uses non-reusable water jugs, however keep your eyes open for old water jugs behind buildings and beside garbage cans.  Even if they're cracked, you might still be able to use them.
This design is very extremely simple.  It consists of two water jugs stacked with water in the bottom jug and dirt in the top jug.  The top jug is upside down and the bottom is cut off.  The sock is attached to the top jug and dangles into the water.  If this doesn't make sense yet, hold on to your socks (or use them in the project...whatever floats your boat.)
Cut the top off the bottom jug, and the bottom off the top jug.  Check out the pictures if this doesn't make sense.
wallpower68 says: Jan 16, 2013. 5:05 PM
? I know that 'bleach/chlorine decomposes in swimming pools when exposed to sunlight...so am wondering if you just expose the water to sun if that would take care of your chlorine issue. good luck
calskin (author) says: Jan 31, 2013. 5:21 PM
Possibly. I'm really not sure. I don't know how long it takes to get rid of the chlorine either if it's left in the sun... I should look that up.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
