Make an After Image Illusion
15,149
Published
Introduction: Make an After Image Illusion
make your own after image optical illusion.
Step 1: Get a Pic
get your picture you can use almost
any picture
(im using the mona lisa)
Step 2: Open Paint
open pant and past pic. and make a white dot in the middle
then press ctrl i
    • Pets Challenge
      Pets Challenge
    • Make it Move Contest
    • Clocks Contest
      Clocks Contest
    9 Comments
    Hello, and welcome to the Instructables community! This currently does not meet our criteria for an Instructable. A completed Instructable:
    - details a finished project with instruction (not just links to instructions)
    - has clear images that you took of your project (web-found clip-art is not acceptable)
    - uses proper spelling and grammar
    - contains appropriate cautions or safety considerations
    - does not violate someone else's copyright
    - does not violate the Instructables terms of service
    - is typically written about something you are very passionate about and want to share.
    If this is a comment, a question, a small tip, or something that cannot truly be a finish project, please post it as a forum topic. If you are looking to start a collaboration, post a topic in the forums. Look here for tips on writing a great Instructable.
    https://www.instructables.com/id/ELHMNOA69REUF10WM7/
    So, it has been unpublished. Please do not republish until it has been corrected. When you republish, if everything is fixed, I'll remove this note. Multiple attempts to republish without correction will result in deletion.
    is this supposed to be the illusion? Inverted colours?
    well i have windows 7 i did it on paint but it didn't work ??
    i'll finish his ible. stare at the dot for 30 seconds, then blinc repetitively at a blank peice of paper
    So.... hmmm... what´s the point??
    You don't need to put a white dot in the middle... You just have to have a certain point to focus on in the middle.
