Make Boxes From Paint Samples
346
8
Posted
Introduction: Make Boxes From Paint Samples
This is how to create small or large boxes from paint samples. This can be used as anything from a DIY couples wedding ring box to small storage compartment. You can convert the measurements from centimeters to inches if you can find big enough samples! The samples are free and i got mine from Homebase.
Step 1: Step 1: the Base
To make the bottom box you must make a square piece of sample that is 5cm/" by 5cm/".
Next, from each corner measure across each way 1.5 cm/". (see the photo) Join up all of the marks with dotted lines, these will be your fold lines.
Then, cut a line into the inner square from one of each corners. (again, see photo!)
Finally, glue all the tabs to the inside. I used double sided sticky tape as it is neater and you can take it apart.
Step 2: Step 2: the Lid
Cut out a square that is 3cm/".
Do the same as the base but change the gap to 0.5cm/" as this is for the lid so it shouldn't be as tall.
Again make the cuts and stick it together.
And there is a little box if you use cm and big if you use ".
Please vote me for the competition as it only takes a second and you could make me very happy is i get a prize, thanks.
    • Trash to Treasure
      Trash to Treasure
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
