3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Make Conductive Glue and Glue a Circuit
This is an instructable on the best conductive glue I have been able to make that uses easy to obtain materials, glues well to most materials, is quite flexible and has a low resistance. Unfortunately for me, it uses a rubber or plastic mixture that I do not know the chemical composition of, so I cannot patent it.
There are many kinds of conductive epoxies, glues, and rubbers available. Unfortunately, they are for the most part quite expensive.
So, for more than four years, I have been trying every possible combination of likely elements, compounds, and solvents that I could get my hands on, in order to make my own truly affordable conductive glue. While I have found several that have excellent low conductivity, they tend to be quite brittle and have a tendency to crack. The conductive glue presented here does not have these problems.
Because this glue is quite flexible and you can vary its resistance, it has potential for different kinds of paint on sensors for robots or other devices. It should be possible to paint on strain gauges on the outside of a regular glove and use it for virtual reality or other control possibilities. Touch sensors and membrane switches can be painted on various flexible or rigid surfaces.
It can be used to paint on wires and resistors and as a glued solder joint. It can also be used to paint on strain gauges, temperature sensors, electromagnetic shielding, antennas, and push-button switches. I suspect, that with more experimentation, it may be possible to use it to create capacitors, diodes and transistors.
Step 1Materials for the Conductive Glue and Circuit
Carbon Graphite, fine powder-Available in larger quantities at http://www.elementalscientific.net/
Available in smaller quantities at your local hardware store. It's called lubricating graphite and comes in small tubes or bottles. The brand I used successfully is called AGS Extra Fine Graphite, but no doubt there are other brands that will also work.
Performix(tm) liquid tape, black-Available at Wal-Mart or http://www.buytape.com
Mixing cups or glass container
1/4 and 1/2 teaspoon measuring spoons
Glass or plastic mixing rod
Cardboard for stencil
Toluol paint thinner (optional)-Available at most hardware stores.
Conductive thread (optional)-Available in larger spools at http://members.shaw.ca/ubik/thread/order.html It is available in smaller spools at
http://www.Inklesspress.com/electronic_parts_2.htm
Circuit materials of your choice
221 comments
1-40 of 221next »
May 18, 2012. 8:22 AMLuziviech says:
Umm. I want to make sum conductive adhesive, too, but i dunno where to get Performix as i'm outta USA, nor do i know what i can use instead. Second problem i got is: what is the graphite for and how do i dose it? I came along sum other howto ( http://smackaay.com/2009/01/13/making-a-conductive-adhesive/ ) and so i got sum useful glue plus the mentioned iron filings, but yet no idea for the graphite's use and its amount.
I would really appreciate, if you could help. Though knowing instructables, i came here via your website and i'd say that the pict of your trials with different materials are proof enough of your competence, so maybe could you even give a comment about the benefit of the alien howto?
Greetz,
Luke
Feb 24, 2012. 5:02 PMolrob says:
I am trying to connect to the + and - of a battery cell. These are calls I obtained by taking apart battery packs (14.4 V and 18 V). When done properly the tab which is welded to the battery posts is obtained and one can solder to the tab. Sometimes the tab comes off and I have nothing to solder to for connections.
Could i use the conductive glue you have explored to connect a copper tab to a battery post?
The glue needs some strength and low resistance and carry some amps of current.
Thanks, olrob
Feb 28, 2012. 8:26 AMolrob says:
Did you try grinding a silver spoon (knife, fork) and collect the silver particles? There are a number of silver epoxies around with excellent conductive properties. I was inquiring about one that I could buy for $25 for 5 grams but that weight corresponds to about 2 dabs ( two trials) with a dab of the epoxy between a cell post and a copper strip which is very expensive.
Feb 25, 2012. 10:37 AMolrob says:
Thanks Mikey77. when I measure a 1" tab that is welded to a + or - post I get 1.4 ohms from one end to the other with alligator clips on each end. Does any of your trials have a resistance near 1.4 ohms?
A 14.4 V Craftsman NICD battery pack delivers from 1.2 to 2.2 amps (quality & price). It contains 12 1.2 V cells in series. NiMH cells can produce 3.2 to 4.5 amps at 1.2 V. Li-Ion cells are rated at 3.6 V and 2.6 amps each.
One of my applications is a Skil Twist battery powered screwdriver. It uses 2 NICD cells in series for 2.4 V and 2 amps in an intermittent operation. I would guess that each screwing operation would have 30 seconds on and 30 second off.
My Craftsman 14.4 v power screwdriver would work about the same (2 amps for 30 seconds).
Would your lowest resistance mixtures still smoke with a 2 amp 30 second cycle?
Thanks again.
Feb 25, 2012. 11:06 AMolrob says:
I see that 3M™ 1181 EMI Copper Foil Shielding Tape has excellent conductivity (.005 ohm) and it's solderable. A small piece of the tape could be bonded to a battery post and a tab could be soldered to the tape. Their conductive acrylic pressure-sensitive adhesive is the key. Have you tried anything like that?
Thanks
Jan 8, 2012. 8:29 AMmotleyjust says:
Nice I can use this. Thanks.
The link http://www.Inklesspress.com/electronic_parts_2.htm
for smaller spools conductive thread doesn't work.
Feb 18, 2011. 11:01 PMthelastonekills says:
this should work with other plastics and epoxy resein right?
Feb 25, 2011. 9:25 AMDIYShared says:
Yes, but you will have to try your own formulations. I have tried with pva school glue and an organic-solvent-synthetic-rubber glue, but this late one is more hard to handle because it cures to fast. I have tried epoxy resin also and it performed very badly.
Sep 11, 2011. 9:01 PMflyingpuppy says:
Have you tried hot glue?
Sep 22, 2011. 5:42 PMDIYShared says:
No, but I guess it will not work. I cannot even imagine a way to do it, maybe you will have to make your own sticks with metal powder heavily embedded on it.
Jan 2, 2012. 9:53 AMAgentfern says:
You could make a mold of the glu gun sticks, melt the glue, mix in the graphite in and mould it back into shape
Aug 31, 2011. 4:50 PMzack247 says:
how well did the school glue work?
Sep 22, 2011. 5:45 PMDIYShared says:
It works well to make paper circuits, check it at: http://www.youtube.com/watch?v=D2l9fKVTICw
Sep 22, 2011. 5:46 PMDIYShared says:
Dec 15, 2011. 8:17 PMxile6 says:
I didnt read all the comments but has anyone tried metal shaving? I work on cars and ive grind down some pipes before. And im left with this metal dust. So couldnt i use that alone with the glue?
Jan 2, 2012. 9:50 AMAgentfern says:
You probably could, i dont see why not.
Sep 24, 2011. 3:17 PMExocetid says:
Excellent Instructable and you "did an Edison" in your search for a solution to a common problem. Bravo!
Sep 24, 2011. 12:03 PMviolentorchid says:
What are you using for this circuit, where is you diagram? Interesting instructable, but it could use a little more explanation. However, if you have included these things, they are so buried in words it's nearly impossible to find them. ie: clarification, please!
Sep 11, 2011. 5:22 AMThisLooksInteresting... says:
thetapeworks.com doesnt supply liquid tape anymore...
buytape.com does though, and its run by the same people
btw, love this idea!!
Sep 13, 2011. 1:57 AMThisLooksInteresting... says:
no problem
Sep 11, 2011. 2:31 PMpietzeekoe says:
How a bout conductive ink so you can draw and maybe even print circuits.
Jul 15, 2007. 1:40 PMdannydutton says:
What is "A" for?
Jan 5, 2010. 1:16 AMadnimo says:
 probably a decade counter or similar linear device with a built in oscillator.
Sep 11, 2011. 12:51 PMSlightlyToastedButDead says:
Oh wait it's a picaxe...
Sep 11, 2011. 12:49 PMSlightlyToastedButDead says:
Definitely not a decade counter because it only has 8 pins. But pretty sure your right on the latter.
Sep 10, 2011. 7:22 AMKaisei13 says:
I am going to be using your glue for an upcoming project. Do you mind if I refer to this instructable?
Sep 11, 2011. 10:24 AMjkachursky says:
Does anyone know if this could be used to create a gel battery?
Sep 10, 2011. 1:21 PMponyballs1 says:
VOAH
Sep 10, 2011. 8:02 AMSupergoob says:
What about acetone as a thinner? Tourmaline can also conduct a charge but not sure if crushing it into a powder would work. Have to try myself. Thank you for this instructable so very much.
Sep 10, 2011. 5:00 AMMr. Reprobate says:
mikey77 -
Very well done. I'm sure you've played down a little bit, the many hours you have invested in this (it must have been a huge job doing trial & error on all possible ingredients & various ratios). That alone, makes you a true "stand-up guy" for posting this as an "open source" formula. Also, I imagine those Liquid Tape guys would have some issues if you tried to patten a formula made of 50% of their product :-) I just wanted to add my thanks as this is something that many of us will use often.
Are you familiar with Sugru? Lots of info on this site. I wonder what you might be able to create by incorporating it into your graphite formula? Maybe a custom sized & shaped 3D switch, resistor, or volt reg / potentiometer disguised as some decorative part of a project? A more HD pressure sensor? I see a huge novelty market for fun car accessories such as the OEM-looking shift knob. You wire it so that it delivers a (safe but meaningful) "zzaaapp" every time your kid dives the family car like a race car? Electric side moulding for those inconsiderate people who lean against other people's cars as if they were beach chairs. Hmmm, I wonder if they'd even mix in a useful way. Hey great job and thanks for making it available to all.
Aug 31, 2011. 4:47 PMzack247 says:
would it be possible to use a paint brush to apply the glue? i need it to be applied thin, i am going to try and fix a touch screen with it.
Aug 11, 2011. 3:32 PMSilentDirge says:
I'm curious, would Isopropyl Alcohol work as a proper solvent substitute? The closest thing to toluene in my hardware store is Lacquer Thinner which is actually an exotic mix of number chemicals so I'd prefer to avoid it. Would Acetone work better?
Jul 13, 2011. 6:50 PMredkcir says:
I was looking for a way to change the batteries in one of my cordless tools (a Black & Decker VPX system). They quit making the battery (a 7volt unit) and I found some rechargeable Lithium 3.2 volt at WallyWorld for $5 a four pack of 600mAH. I really didn't want to try soldering the leads to it, and this looks to be a much better way. Thanks for the Info.
Jul 25, 2010. 6:42 PMDELETED_madscientist167 says:
(removed by author or community request)
Mar 31, 2011. 4:57 AMperlygatekeeper says:
powered iron would work, iron oxide is red and is not conductive
Sep 24, 2009. 6:37 PMjingerfinger says:
I am trying out crushing 2B pencil leads and mixing them with paper glue. Just for those tiny projects. Hope I remember to report my findings :)
Mar 31, 2011. 4:51 AMperlygatekeeper says:
graphite in pencil "leads" are a mix of clay and graphite. the softer the pencil the more graphite. you can buy pure graphite power sold as a lubricant, in small plastic tubes. (you want the black lube, it says it's graphite on the tube, they also sell a white lube which I think is a silicone product). You can buy this product at any good hobby store (it's used for pine wood derby cars) or at hardware stores.
It works well in locks.
If you insist on crushing some graphite yourself, art stores sell sticks of pure graphite for drawing, and some good calligraphy boxed sets come with graphite and a little ceramic bowl for making black "ink".
1-40 of 221next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
388
Author:mikey77
I believe that the purpose of life is to learn how to do our best and not give in to the weaker way.
