make cutlery for a leatherman
In this Instructable I'm going to show how to make cutlery for a leatherman surge.
Step 1What you will need
what you will need
You will need:
- stainless steel cutlery (I recommend old cutlery because new cutlery is way to expensive)
- sandpaper (dont know what grit but its one fine grit and one rough grit)
- grinding wheel
- work gloves
- safety goggles
- paper
- fineliner
- glue
- Scissors
- handsaw (for metal)
- waterproof marker
for your own safety
were the work gloves and safety goggles
while working with a grinding wheel
19 comments
Oct 6, 2009. 7:01 PMberky93 says:
How can you tell if a leatherman has the ability to attach to utensils such as this? I plan to buy one soon and I'd like to be able to make my own, such as these
Oct 6, 2009. 7:12 PMberky93 says:
never mid, I found it. The ones thaat can change blades are listed as having a "blade exchanger"
so far the only one I can find that is made by Leatherman with this blade exchanger is the Surge:
http://www.leatherman.com/multi-tools/full-size-tools/surge.aspx
Apr 18, 2010. 5:30 AMaTOMx says:
Having the Leatherman Wave, I have the Large bit driver that would be good as well to hold the fork and spoon.
Sep 14, 2010. 10:13 AMBOOM5601 says:
That's not a bad idea. Wave ftw.
Aug 20, 2009. 3:59 PMClayChip says:
I think this is a great idea. Can you close the leatherman with the utensil attached?
Oct 6, 2009. 6:17 PMberky93 says:
I doubt it since the utensil is so big, but it definitely decreases the overall size of everything, you could probably fit a leatherman and a few utensils in one carrying case (that wont end up being as long as a standard fork)
Aug 28, 2009. 10:33 AMwilwrk4tls says:
This is definitely a great idea. One of the few I will probably really end up doing myself. Might even be cool enough to justify a second Leatherman that accepts the jigsaw blades... or just act as a knife to complement the fork.
Aug 21, 2009. 9:27 AMLight DaX says:
hey buddy nice TUT GreatZ a good friend
Aug 20, 2009. 10:09 AMCaseyCase says:
Sandpaper comes in different "grits."
Aug 21, 2009. 7:07 AMCaseyCase says:
Your instructable still rocks!
Aug 20, 2009. 6:49 PMthepelton says:
The higher the number, the finer the grit. Smaller numbers are good for initial smoothing of a surface. Higher numbers, used in sequence, lower to higher, can help you make scratches dissappear, so you can get wood which looks almost like cast plastic, or wood simulated glass.
Aug 20, 2009. 6:37 AMTURBOSOPPEN says:
cool! but there is a major problem with this,the problem comes when got to use a fork AND a knife at the same time, like when you eat meat.
Aug 20, 2009. 2:56 PMjolshefsky says:
How can you live with only one Leatherman tool? :-)
Aug 20, 2009. 5:02 PMcorey_caffeine says:
better that if you have multiples
Aug 20, 2009. 11:59 AMmonkeysee says:
very nice, this caught my eye with your title but unfortunately I've got a smaller juice S2 which doesn't have the ability to attach other utensils. none the less i still think this is a great idea.
Aug 20, 2009. 5:59 AMJayefuu says:
Pretty cool!
Aug 20, 2009. 5:57 AMmikaelthemycologist says:
awesome......
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:THATS ME
