Step 1: What you will need
- stainless steel cutlery (I recommend old cutlery because new cutlery is way to expensive)
- sandpaper (dont know what grit but its one fine grit and one rough grit)
- grinding wheel
- work gloves
- safety goggles
- paper
- fineliner
- glue
- Scissors
- handsaw (for metal)
- waterproof marker
for your own safety
were the work gloves and safety goggles
while working with a grinding wheel
Step 2: Copy and cut
-than cut it out (cut it out as precise as possible because
it will make work easier later on)
Step 3: Mark and paste
- than glue your copy on behind your line
Step 4: Cut and grind
- after the cutting you have to grind off the big pieces
- cool your project ones in a while so you don't burn your fingers
Step 5: More grinding
Try to follow the outline of your copy exactly.
When you are done with grinding the outline you try to fit it in your leatherman.
Keep grinding small bits off until your cutlery fits in nicely.
Step 6: Sanding and more sanding
You can use all sorts of grits. Start with a low grit for the deep scratches and then
work your way up to higher grits to get a nice smooth finish.
tip
when using
high grits it's
advised to make
your project wet.
Visit Our Store »
Go Pro Today »
so far the only one I can find that is made by Leatherman with this blade exchanger is the Surge:
http://www.leatherman.com/multi-tools/full-size-tools/surge.aspx
