3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
make plastic 3D models from CAD designs using an automated "milling machine"
Step 5Get ready to mill
get ready to mill
you'll need to mount you plastic in a stable way so that it doesn't shift during milling. The EGX comes with clamps to help do this.
The way I did it is:
I stuck plastic slabs to the EGX bed using mounting tape. I made a .3dm CAD file which had two 1mm diameter holes, one on each side of a large slab. I send these to visual mill and the EGX which drilled holes into the plastic taped to the EGX bed.
I used these holes to put dowel pins in, so all future plastic that I mill with the EGX gets mounted on these pins (have to drill 1mm holes into each plastic slab that I want to mill). (use the same .3dm file I used for the original bed drilling)
After mounting my project plastic onto the dowel pins, I also put melted glue with a glue gun all around the piece to keep it even more stable. This isn't very necessary.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
81
Author:leevonk
www.leevonk.com
