3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
make your own charcoal
bqqing is always nice and nicer when you dont have to spend to get charcoal
and this is my way of having the fun of childish fire starting plus getting charcoal to grill on later
Step 1What you will need
what you will need
what you will need :
*wood
*a sealable bqq or other thing (mine is made of cast iron and isnt so big)
*something to seal it with (is use a container with water in it and some potting soil)
*something to light it with
32 comments
Jul 14, 2011. 4:41 PMcablemonkey says:
The idea here is to heat the wood in an oxygen-free environment to drive off (almost) everything except the carbon.
I use a similar process to make charcoal for pyrotechnic effects.
Get a clean unlined gallon can or two at a paint store or larger hardware store for a couple of dollars. Drill or punch a small hole in the lid, and then fill it with sticks about 1 in square. I usually use scrap 2x4 or lath, cut to just a bit shorter than the can and then split into smaller pieces so I can fill the can right up.
The lid then gets tapped on securely and then the can goes in a hot fire for about 45 minutes to an hour. Steam and other gasses will come out of the hole in the lid and as the water content decreases, this plume will ignite. It makes a lot of noise, produces a large jet of fire, and can be quite smelly, so don't do this part in your fireplace.
Once the plume has died down, I pull the can out of the fire and set it somewhere to cool. Some people cover the hole at this point with a coin or something. I've never worrief about it. 30-45 mins later the can is cool to the touch and your charcoal can be removed.
There's a good article on skylighter.com outlining this method at http://www.skylighter. com/skylighter_info_pages/article.asp?Item=109#char
Mar 18, 2012. 6:31 PMchrometailpipe says:
Can I use this the same as activated carbon to filter rain water and drink it? Or are there other steps to purify the charcoal further?
Mar 18, 2012. 7:41 PMcablemonkey says:
I don't really know. Probably? A quick scan of the activated carbon wiki indicates that the ash content can be important. I would suggest some more research might be in order here.
Jul 17, 2011. 10:03 AMrippa700 says:
If you want nice drawing charcoal use peeled willow sticks and pack the can with sand to keep then straight and whole.
Jul 14, 2011. 3:46 PMTim Temple says:
So basically you can get the same result by putting a sealed can of wood in the oven and set it on self-cleaning, right? :-)
Jul 14, 2011. 5:03 PMjohnny3h says:
NO, NO, NO.  The process of heating any combustible material to ignition temperature WITOUT the presense of OXYGEN[AIR] is called Pyrolisis, and THOSE GASSES BEING DRIVEN OUT OF THE WOOD [or any combustible material] WHEN REACHING and mixing with AIR become  EXPLOSIVE, AND VERY TOXIC!!!!!
You can consider those gasses coming out of that hole in the can the SAME as turning on a NATURAL GAS VALVE and not igniting it.
IF and once that gas envelope mixes with the air in your kitchen, AND WHEN that Oxygenated gas reaches a SOURCE OF IGNITION [like a pilot light, a spark of any kind as in turning a light switch on or off, or a relay in a refrigherator snaping, or any countertop appliance turned on, running, or off] then that spark could [probably will] ignite the "cloud" of explosive gas, AND you will have a major explosion in your kitchen, and probably a resulting fire.
Even if this should not occur, the toxic gasses will be harmful, AND could BE FATAL [KILL YOU!].
Do NOT attempt to make charcoal indoors.  Do it OUTSIDE, or under something like a carport which is open on at least 3 sides.
Jul 14, 2011. 8:47 PMlukeyj15 says:
Ok, this can be done inside. I have done so. But what he is trying to convey, is the gases driven off are flammible. But I would be more worried about filling the kitchen with smoke. I have done this successfully in a sealed tin with a hole in the lid placed into my wood stove and left until no more flames are exiting the hole. I would then take it outside and seal the hole until it cooled off. Because I was doing it in a properly ventilated stove, (Had a working chimney) There wasn't any larger risk than burning wood normally would.
(Please note the wood stove has to have a fire in it for this to work)
Jul 18, 2011. 10:01 AMslowburnaz says:
Yes... I believe the gas being produced is going to be primarily methane, if I remember my middle school science class correctly.
Jul 14, 2011. 10:33 PMmarcintosh says:
I've seen the locals in Saint Lucia make charcoal by building a rick, setting fire to it and when all of it is alight, they cover it with dirt and then the most important part - they go have a few beers and wait for it to be done.
Thanks for helping me remember some fun times in the Caribbean.
M
Jul 14, 2011. 1:29 PMuzziah0 says:
You start with a fire, then there is some sort of rim or can or something with water in or inside it? Not sure what you are doing?
I think I would get a better idea if you had a description of the process; I don't know what goes into making charcoal. You just start with how to do it, so I'm lost from the beginning.
Then from the picture with the fire you go to one with the rim or can. Is that a ring with no bottom or a can? You pour the water right on the fire, or in a can (I'm not sure what either would do to help make charcoal)?
I don't really know what you are doing. I'm thinking you are not pouring the water directly on the fire, but I don't know what is going on.
Then, it looks like you pack some dirt around the ring that goes on the fire.
Maybe a diagram and pictures of the rim thing before it gets put on the fire, and then after it is on the fire before you add the water? Sorry if I am being critical, I'm just confused as to what you are doing!
Jul 14, 2011. 2:50 PMsoulinstructar223 says:
@ uzziah0
I agree the directions could be in more detail but from what i got out of it the thing with the water in it is in fact a can of some sort. The water is simply there to help dissipate the heat from the burning wood/charcoal. The raised ring around the outside appears to be part of the container that the burning wood is in (compare the photos). It appears the dirt is packed around the can to prevent any smoke/air from getting in/out and to help smother the fire to put it out. So, in summary, the water doesn't touch the fire and the dirt is just packed around the outside of the can to help seal in the fire to put it out by smothering it. That's my take on it anyway. I don't know enough about this process to know whether or not this actually produces charcoal or not.
Jul 14, 2011. 8:36 AMChicken Spit says:
So the main idea is to "half burn" wood then seal the container so it doesn't keep oxidizing?
Jul 14, 2011. 7:09 AMGBMorris says:
How long do you let it burn before you seal it off?
Jul 11, 2011. 4:57 PMrimar2000 says:
Good info!
Do you use any firewood, or it have to be hard? Here there are a lot of soft wood from pruning. We are in winter.
Jul 13, 2011. 5:04 AMrimar2000 says:
Thanks. Perhaps softwood produces a shorter-lasting charcoal.
Jul 11, 2011. 9:07 PMironsmiter says:
hard wood charcoal works BEST.
But soft woods can be used.
Especially fruit woods.
Try to avoid pine though. there's a LOT of resin in pine, and to make good charcoal, well, it doesn't work REAL well.
If you plan on doing a LOT of charcoal making, consider stepping it up to something like this
http://www.instructables.com/id/How-to-Make-some-Charcoal/
Aug 25, 2011. 9:43 AMrjogden says:
You're confusing "softwoods" with "soft wood". Fruit trees (apples, pears, cherries, peaches, etc.) are "hardwoods". I know it's confusing...
Aug 26, 2011. 5:36 AMrimar2000 says:
Yes, I was convinced that "softwood" and "soft wood" was the same thing. I speak Spanish, no English.
Thanks for the clarification!
Aug 26, 2011. 11:11 PMironsmiter says:
Actually, I WAS trying to get across the idea of soft vs hard wood. not softwood vs hardwood.
To be clearer, i SHOULD have said DENSE wood versus LESS DENSE woods.
rjogden, I agree, SOME fruit woods work well for charcoal.
Others, however, are of the less dense variety, and do NOT work well. :-(
Pear, Apple, young Cherry and Hazel are all species that make less than satisfactory charcoal for use in forges.
If you're making it for your barbecue... go ahead and use any wood you like :-)
they will all produce enough heat to grill your meat.
"The Definitions of Hardwood and Softwood
All hardwood trees are angiosperms. This means that they produce seeds which have a protective covering such as fruit or a seed with a shell. Softwoods are determined by their seeds also.
Trees which are softwood are called gymnosperms and they are determined as having seeds which do not have any sort of protective covering whatsoever. Most people believe that a hardwood will be more dense than a softwood and, although this is often the case, it is not always a true statement. For instance, there is a wood known as balsa wood which is one of the lightest woods around. It is highly pliable and is one of the lowest density woods available, but, it is still considered to be a hardwood because it comes from an angiosperm tree. "
Aug 27, 2011. 9:49 AMrimar2000 says:
So the English also has "boobytraps" as Spanish!
Aug 27, 2011. 9:41 AMrjogden says:
Mostly I use charcoal for making black powder. The lighter, less dense and low-ash woods have the potential to make the fastest-burning powder. "Softwoods" like pines are high in high-molecular-weight resins that volatilize more slowly; they are mostly used for their spark effects. To a great extent the properties of the resulting powder are the result of the actual charcoal-making process, temperature and length of time in the kiln being foremost in importance. Excessive temperatures or over-cooking causes formation of graphite, which burns more slowly. Under-cooking results in remnants of wood which also slow the burn rate. We also try to exclude all air, because allowing the carbon source to oxidize increases the final relative ash content of the resulting charcoal.
I guess the bottom line is that you must select the wood and adjust the process to fit your intended use.
Aug 28, 2011. 6:50 AMrimar2000 says:
When I was a kid and did experiments with fireworks, I could see the huge difference between using hardwood charcoal and charcoal from pine. The first burned slowly, the second producing a flash.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:windstalker1992(me on DA )
