Introduction: Making a Better Blade
Picture of Making a Better Blade
My blades constantly snap while cutting hard objects, and i am afraid that the flying shrapnel might hit me. I decided to create a better blade that won't snap, be safer, and can stay sharp longer.
Step 1: What You Need
Picture of What You Need
-pliers
-your blade
-lighter
Step 2:
Picture of
hold the blade with the pliers, and put the flame of the lighter onto the blade until it turns black. The blade can be soaked in water or left to in the air.
Step 3: Stress Test
Picture of Stress Test
I bent the blades by pushing the blades on the table sideways to bend it. Then untreated blade snapped after 5 times of bending, the parts of the blade flew across the room. The treated one did not snap, even after 20 times of bending causing it to be safer than the other.
Dustin Rogers (author)2015-04-11
Yep, you annealed it which made it softer. It is now less likely to snap, but will dull much faster too.
sixsmith (author)2015-04-11
I don't see how these will stay sharper longer, what you have done is annealed the steel and made it softer, unless it's an air hardening steel. I can't say that I've ever had one of those knives snap, the trick for a lot of items is to make multiple passes with light pressure.
About This Instructable
1,135views
18favorites
License:
More by AlexZhang:Recovering 18650 Lithium Batteries With Only a PaperclipMason Jar Solar LED Fairy Lights$1 USB BATTERY BANK FROM OLD LAPTOP CELLS
Add instructable to:
