Making Concrete Balls
241,716
660
76
Published
Introduction: Making Concrete Balls
After seeing industrial geometric accessories for the home and garden I wanted to make some for myself.  They are really easy and I'm sure you'll enjoy working with concrete too.  The possibilities are endless!  Thanks!
Step 1: Getting Organized
Gather your supplies and tools together.  Tools include: safety glasses, rubber gloves, leather gloves, a hammer, old newspaper, a scoop (old yoghurt container).  The safety glasses and gloves aren't in the photo 'cause I'm wearing them...you should too.  And, you should also be wearing closed toe shoes.
I also had a garbage can lid which made great trays for working - you'll see it later photos and most importantly, you need an assortment of forms to mold the concrete.  I also had a bucket of water for rinsing.
The forms that I uses were salvaged glass light shades.  I had four different sizes and had them nearby and ready to use.   Materials include 'Quikrete' concrete mix and water.
Step 2: Plan Ahead
So, one of the forms that I used broke in the middle of the concrete filling/mixing step.  Fortunately I had a Plan B and was able to quickly switch to another form that I hadn't been planning to use.  Because I had an assortment of forms ready to go, I didn't waste all that wet quick setting concrete.  I was lucky that the forms I used were small and sturdy.  Because I was working in a 'tray', I didn't have to huge mess to clean up....just a small mess.
Step 3: Filling the Form
To make the concrete balls, the glass form is actually broken and discarded.  I set the form on the garbage can 'working tray.  I also recommend lining the 'tray' with old newspaper for easier cleanup.  Using the 'scoop', I carefully placed the dry concrete mix into the form then added water.  I recommended alternating between adding concrete and adding water.  Even for the small form, it was hard to mix in the water and make sure that the concrete was evenly mixed with water.  Using the handy disposable stir stick (nothing fancy, just a twig from the garden) mix the dry concrete with water.  Set the filled form aside and wait.
Step 4: Freeing the Concrete
So for the 2nd concrete ball, I lined the working tray with old newspaper.  While wearing safety glasses and heavy gloves, gently tap the glass to break it.  I used one hand as a shield between me and the glass.  For the 1st ball, I didn't wait and wasn't tidy and cracked the glass in the working tray with wet concrete.  Getting the broken glass out of the set concrete is going to be a challenge and I'm not looking forward to it....so don't do that!
Step 5: Cleaning Up
Now is a good time to bundle up the broken glass and carefully dispose of the waste.  Still wearing gloves, I also rinsed the concrete ball off.  I had rinsed my gloved hands and the finished concrete  ball in a bucket of water.  This water is alkaline so be thoughtful and careful when discarding the water.  Please don't dump it down a storm drain - save the fish!  An be careful dumping the water in the garden....the lawn and your plants won't like it.
Step 6: The Big Finish
So now the concrete ball is free on the formwork and your beautiful, unique accessory for your home.....or is it?  The concrete could be painted.  I might tile a concrete ball with pennies.  I'd also like to cover the concrete with moss. Or I might leave it as is...I like the texture.   Who knows, the possibilities are endless.
2 People Made This Project!
  • Make it Move Contest
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
76 Comments
Now that was pretty neat. I'm liking this idea.
These balls would make nice ammo for my Trebuchet to toss !
I've been thinking of doing something like this but cannot find a large enough sphere for my purpose. I'm curious, do you have any thoughts on where to find larger spheres that are strong enough to handle the weight of the concrete? Something about 24" in diameter?
Wrap an exercise ball with some chicken wire strips (tape the edges so they don't poke the ball), then apply the concrete, perhaps two or more layers, drying in between applications. That way it's hollow and therefore able to be picked up. O'wise, you'll need a truck to move them.
what size are you think of making? Solid concrete balls are heavy!
I've also got a book on concrete decorations, including instructions on making hollow concrete balls (with chicken wire mesh). It kind of looks like paper mache with concrete.
I was thinking about 24" diameter for some lawn decorations. I thought about using some salvaged naval buoys but they are still too expensive. Maybe one of those exercise balls reinforced with fiberglass would work. Or I could just make smaller lawn ornaments.
You could use cellular concrete to keep them light.
I make foam cement down to about 20-25 pounds / cu ft.
using a foaming agent .
Impress the girls playing catch with your concrete balls.
Or you can easily make them so they float.
Concrete balls that size would weigh about 630 lbs. after curing. Vermiculite concrete is said to weigh 15% of what normal concrete weighs, and that would get you down to 94 lbs. If I were you, I'd coat a 24" exercise ball with expanding foam insulation (a.k.a. "Great Stuff") to about 8" or 10" thickness, except around the nipple. Build a 30" plywood box, and trim the foam so that the ball fits inside tightly, with the nipple-side up. Cut away the ball at the nipple. I'd either hang the ball from the nipple somehow, or attach the nipple loosely to a piece of plywood so it's at the bottom. (It's not critical, as long as the area around the nipple stays uncoated.
Will the foam melt the ball? Will the foam stick to the ball long enough to expand around it? Will differential expansion distort the ball? I dunno.
I would think that 24" diameter forms would take an awful lot of concrete and would be extremely heavy.
Get a big cheap plastic ball and cut a hole in it. Cut it off when the concrete is set. If you cut the hole so that there is a piece left for a hinge, you might get the "sprue" to be spherical rather than flat.
I've seen a few molds for sale online for making "Atlas stones" for strongman training. They're usually thick plastic hemispheres that bolt together, with a hole in top for pouring. The ones I've seen are pretty expensive though, so if anyone knows of a cheaper alternative, that'd be great.
Awesome project!
I am going to do this for my school speech!
Where can you get the globes from to make these, really excited to think about these, Thanks for sharing
i am not a chemist-''alkaline solution'' could another chemical be added to this, to make the solution less injurious?
Yes anything acidic really...but it isn't really necessary as it wont be too bad in small quantities. Think of the amount of cement and concrete builders wash off and so you can guess that this tiny amount will really make little difference. Also is not hugely harmful to you but obviously don't be stupid and ruin your soils chemical make-up by chucking it in the flower beds. i would just wait until you are sure all the cement is set then pour it into the sewer drain (not down the toilet though). It would be easier just to put it in a patch of ground that you don't see like behind a shed or something.
maybe, but I'm not a chemist either...maybe someone else will pipe up
Citrus juice or any other kind of acid will neutralize the alkalinity. Add until it stops reacting strongly.
For a round shape, you could use perhaps a plastic child's ball from a dollar store or yard sale, if it would regain its shape after having a hole cut in it and being filled with concrete.
http://www.ebay.com/itm/400099878397?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
NEW plastic mold half sphere 4" W concrete plaster mold
NEW plastic mold half sphere 8" W concrete plaster mold
http://www.ebay.com/itm/NEW-plastic-mold-half-sphere-8-W-concrete-plaster-mold-/140986896936?pt=LH_DefaultDomain_0&hash=item20d3795228
