Making Custom Dremel Bits
17,752
98
6
Published
Introduction: Making Custom Dremel Bits
these are some ideas i came up with or modified from others on making your own bits for the dremel.
-=i take no responsibility for your actions=-
Step 1: Bottle Cap Saw Blades
I saw an instructable for making saw blades out of commercial buttons and I figured a way to modify it with bottle caps which are more common to have. (credit given to "harari" for this idea)
-=this blade is designed to cut hard plastic, also when cutting plastic it may create toxic fumes=-
Everything for this comes with the dremel 4000 kit except for a hammer vice and bottle cap.You will also need the following bits: #432 #402 #107 #84922.
First off get a cap (I like to use samuel adams caps) and flatten the edges but make sure they ridges fold outward and not inward, you can use the corner of the vice to do a little bit at a time.
after flattening the cap use bits #407 and #432 to scrape off the rubber junk on the bottom of the cap and smash the cap in the vice to flatten it some more.
Next poke a hole in the center with a small nail (between the top of the "A" and "M" in adams)
Use bit #107 to clean out the hole.
After that you will use the sander once more to sharpen the edges (it will work fine if you dont do this but its recommended). I tilted the dremel at about a 40* angle or so and sharpened all around.
If you want to make teeth use bit #84922 to carve out small ridges on the edges (again this is optional but recommended).
All you gotta do now is attach it to bit #402 and cut some plastic!
Step 2: Nails As Drill Bits
This is an extremely simple idea that almost any one could do.
All you gotta do is cut off  the head of a nail that can fit in the chuck and you got a drill bit. They would be stronger than regular drill bits as they dont have as many weak spots, also they'll bend instead of breaking under pressure.
There are a few ways of cutting off the head. Of course you could use wire cutters or tin snips but if you want a clean cut you could use the metal cutting saw that comes with the dremel or you could sand down a cut from wire cutters or tin snips.
As nails work well they will create a lot of friction so there will be some smoke. Maybe putting oil on the nail will help.
What Can You Do with a Dremel Tool?
Finalist in the
    • Oil Contest
      Oil Contest
    • Casting Contest
      Casting Contest
    • Make it Move Contest
    6 Comments
    Thanks for this!!! I'm restoring a moped right now and although I don't need a cutter, you've definitely opened doors for me as far as making your own bits. Another one on youtube showed how to make sanding discs with regular sandpaper and some duct tape as backing. I just need to figure out how to make a grinder or wirebrush bit....
    Great tips! My dremel is the No 1 best tool for EVERYTHING! Good work!
    good job!
    I have the same Dremel!!!
    noice! its pretty amazing isnt it!!!
    it does, the first one i made all i did was flatten it and poke a hole in it was it worked fine!
