Introduction: Making Hydrogen and Oxygen
In this instructable I will be explaining how to separate water into hydrogen and oxygen through the method of electrolysis. Electrolysis is where you run a current through a solution containing ions which in this case are hydrogen and oxygen. 2H2O - 2H2 + O2
the setup cost me about $45 New Zealand to make but i had some things already lying about
This project is potentially dangerous, hydrogen in the presents of oxygen will react violently I take no responsibility for any harm you cause yourself or others
also this is my first proper instructable any comments on how I could improve would be appreciated.
Step 1: Gather the Materials
Materials
1. two 3/4 inch diameter galvanized steel pipes.
2. two 3/4 inch diameter galvanized steel end caps.
3. two 1/4 inch stainless steel bolts with nuts (nylocks work well as then you only need two)
4. four 1/4 inch stainless steel washers
5. four 1/4 inch o-ring
6. four seals from plastic bottle lids.
7. 1 valve (two optional if you want to collect both gases
8. Teflon tape
9. water
8. Teflon tape
9. water
Step 2: Preparing the End Caps
Drill one 23/64 inch diameter hole in each of the end caps
Step 3: Preparing the Electrodes
Drill a 1/4 inch hole in two of the bottle seals.
put one washer on each bolt followed by the bottle seal and then two o-rings.
Step 4: Preparing the Electrodes (continued)
push one bolt into the hole in one end cap and the other bolt into the other end cap.
Drill another 1/4 inch hole in the other two bottle seals and push one onto each bolt followed by one washer on each and then a nut and screw down tight.
when screwing down you can wrap wire around the top of the bolt which gives you your connection
make sure that the bolt is vertical in the end cap so it does not touch the sides when put into the pipe.
Step 5: Attaching the End Caps to the Pipes
Wrap Teflon tape around the thread on one end of each pipe. Start from the top an work your way down.
Screw on the end caps tightly.
Step 6: Attaching the Valves
Wrap some more Teflon tape around the two remaining ends of the pipes and screw on the valves tightly.
Step 7: Testing
If you can connect a multimeter set to measure resistance to each wire there should be a very high resistance if not one of the bolts may be touching the pipe in some place which you will have to find and fix.
Fill each pipe with some water and make sure that the water does not escape anywhere
Step 8: Finished
If everything has worked so far connect the wires to a power supply of your choice. (I use a car battery connected to a couple of solar panels)
You may want to and something like salt or baking soda. I would not recommend using salt as it forms chlorine gas which is poisonous but also will react with the water forming HCl and HOCl which are acids.
