Mepalm's Mini Deadly Spray Grenade
1,233
4
11
Posted in PlayKnex
Introduction: Mepalm's Mini Deadly Spray Grenade
About: Hello. My name is <classified> I have an interest of making model guns with k'nex, even though I don't post much at all, I make some guns then never post or remember ever again because they are simply too c...
A small grenade i made to pass the time. Very efficient to pieces only 12 pieces.
Needs one exotic but not necessary. This is my first instructable...yadada. Whatever. Feel free to say anything. I would like contructive ones though. This is not a copy of someone elses. This is V2.
No posting of this without telling me first!
Step 1: Pieces YOU Will Need
1 red connector
2 white connectors
1 grey connector
1 "possibly exotic" black connector/rod in 1!
6 spacers
1 yellow rod
2 rubber bands
Step 2: Step 1!
Simple and easy just follow the picture.
For you that can't see my hi rez picts.....
Attach the red connector middle slot on the yellow rod ends.
Slip in a white connector.
Step 3: Step 2
Slip on the grey connector, not clipped on!
and 6 spacers
Step 4: Last Step
put on the other white connecter at the end and put on the black connector so that it is loose but secures its position. And put on the rubberbands OPPOSITE of each other on the 2 connectors so it doesn't blast out in your face. I used big rubber bands so i doubled back so use small ones to avoid hassle.
Step 5: Ending
This is not all the debris. I just picked them up after the boom. The shrapnel was like 15 m away with right rubberbands like mine so i couln't take picts.
twist and pull of the clip on end...I'M sure you'll find out how. Its on the extra picture and remove the rod. Then throw! Bam explosion. It doesn't look like a real grenade but it does the job. Mod it if you want but give me a rating first.
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    11 Comments
    you need a new name, you are starting to remind me of mepain. and no, this isnt new, ive seen a similar design, but they used those gray connectors instead of spacers.
    1. Whatever.... Mepain is a ****. 2. Yeah, I also saw some similar grenades but they did not look like it, like the XPLODER.
    he isnt a ****, he just banned you because you being 12 is a legal issue if he allowed you to stay.
    WITHOUT EVEN A SINGLE WARNING. WHEN I SIGNED UP I DIDN'T EVEN KNOW YOU SHOULD BE AGED 13+. IT ALSO WASN'T IN THE RULES AT ALL. Sorry.
    Its in the TOS when you register.
    a question for you: do you really' think anyone reads the TOS anywhere? if you do, it's a sad, sad thing...
    i faked my a ge 2 but ill b 13 in a month so i thought "ah whatever"
    NOt the same mech, this is like those horror movies where a pearson gets trapped between two moving walls and the blood squelches out, like in those egyotian horror movies, man they're good
    I didn't get my name from mepain i8 don't ene like his guns I mostly like oompa loompa's and killerk's anyway my name is from naPALM to mePALM i liike it might change soon
    Finally a cooment, Has someone even built it? I mean it is fairly new but build it. I'm telling the truth. Minimum pieces for a deadly blast witch proper bands.
    Your name reminds me of MEPAIN! L0L
