3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
micro gauss rifle
micro gauss rifle
A tiny gauss rifle built from only a few strong magnets. (It's not a coil or rail gun since its got no electromagnets, so I went with gauss rifle.)
Step 1Acquire magnets
Acquire magnets
You will want some strong rare earth (Neodymium) magnets of two sizes. The larger size should be a ring magnet. The smaller magnet can be a ring or cylinder, and should fit snuggly into the first one. You can actually stack together several magnets, but single cylinders might work better.
I get my rare earth magnets from http://www.kjmagnetics.com/
71 comments
1-40 of 71next »
Oct 3, 2010. 2:18 PMCheezpaper says:
some form of RAIL GUNZ FTW!!!
Mar 13, 2008. 9:53 PMmichaeldnash says:
(removed by author or community request)
May 29, 2009. 4:29 PMsythe511 says:
um sorry to burst your bubble, dude 'but magnets, no matter how strong, never, and i mean never, keep their polairity forever.''
Aug 15, 2009. 10:01 PMmettaurlover says:
true, but it would last a really really long time.
Dec 9, 2009. 8:09 PMInmate1440 says:
Actually this would not work at all in order to cause the magnet to go far enough into the other magnets field to be repelled by it you would need to give the magnet more force than the other magnet was capable of producing other wise the magnet would simply repel the other magnet back before it could pass through and be propelled to the next magnet in line. it may work for a while the initial force you give it but eventually the extra bit of energy required to pass through each magnet will stop it. Perpetual motions machines are never going to work because of the fact that energy is always lost. The second law of Thermodynamics states that entropy is always increasing and if you were to build a machine capable of perpetual motion you would be breaking that very law. so unless you plan on rewriting the laws of Thermodynamics then perpetual motion machines are not realistic.
“The law that entropy always increases, holds, I think, the supreme position among the laws of Nature. If someone points out to you that your pet theory of the universe is in disagreement with Maxwell's equations — then so much the worse for Maxwell's equations. If it is found to be contradicted by observation — well, these experimentalists do bungle things sometimes. But if your theory is found to be against the second law of thermodynamics I can give you no hope; there is nothing for it but to collapse in deepest humiliation.” — Sir Arthur Stanley Eddington, The Nature of the Physical World (1927)
Dec 10, 2009. 7:02 AMmettaurlover says:
True, but if you gave it a large enough initial force, it would continue for a very long time and quite possible generate power for longer than a human live.
Dec 12, 2009. 4:56 PMInmate1440 says:
Hypothetically but in order to make electrical energy you would need to somehow harness the kinetic energy and since nothing is 100% efficient it would slow it down faster, and unless you gave it a crazy amount of initial force it would have to generate only a trickle of energy other wise it would stop to quickly to be useful.
Dec 13, 2009. 10:40 PMmettaurlover says:
I mean get it up to the speed of light fast and unstoppably hard. Then it would move forever and generate energy forever. If it decided to go in a circle around a large electromagnetic coil, that is.
Jun 7, 2010. 6:25 AMnutsandbolts_64 says:
it's impossible to make it go the speed of light. Because it would (according to law) grow ever more heavier and heavier so your device will explode/implode.
Jun 7, 2010. 2:01 PMmettaurlover says:
ANCIENT POST. You shouldn't have replied. We were speaking theoretically instead of practically.
Jun 8, 2010. 2:07 AMnutsandbolts_64 says:
lol, sure.
Apr 11, 2010. 7:11 PMInmate1440 says:
 But your still only storing energy. you would have to put the energy in to it in the first place and since you lose energy recapturing it you would be better off just using the initial energy and not wasting the time with a rather pointless device. Unless you wanted to change kinetic energy into electrical energy in which case i would work but the scale would be pointlessly large and this type of device already exists.
Apr 11, 2010. 11:12 PMmettaurlover says:
May 17, 2009. 8:42 AMSgt.Bacon says:
duhhh......my brain hurts now......
Mar 11, 2009. 10:16 AMknotmuch says:
I'm more pro Nuclear
Mar 11, 2009. 10:15 AMknotmuch says:
Once we find a way to assassinate friction, perpetual motion will have a chance. Even if your machine where set up in a COMPLETE vacuum it could run along time unattended (assuming near perfect alignment), now for the dreaded word,
However,
once you attach it to a generator to make electricity you are going to add resistance and/or drag to the system and that will kill the self sustaining hope just as quickly as friction
I'm not trying to be mean or negative.
We can only further our designs and ideas through re-examining them and expanding the scope of variables we take into consideration.
"We are not perfect. There is no complete or absolute solution, only what was good enough the day before."
Feb 24, 2009. 7:29 AMpyroarchist says:
no, gauss rifle style perpetual motion is impossible because everything has to be reset.
Feb 12, 2009. 10:22 PMThundertydus says:
Look up "Coil Gun"
Dec 9, 2008. 5:21 PMKryptonite says:
Ok, great idea but this is impossible, to fit the inside magnet into the outside ones needs a fair bit of force, but if it shot out the end it would not have the speed to go into the next set. Sorry to burst your bubbles. -Kryptonite
Jun 26, 2008. 3:57 PMszechuan53 says:
i personally think hydrogen is the future... PRAISE THE ALMIGHTY "H"
Oct 18, 2008. 8:58 PMkibbler says:
Noooooo! It's the Human Element!
Oct 19, 2008. 10:01 PMszechuan53 says:
BWAHAHA
Oct 16, 2008. 11:15 PMmonkeywithawrench says:
I agree. my hho generator turned into a hho BOMB last friday and exploded about a foot and a half away from my face. now i have to build four more for my science fair project because my generator turned into a BOMB. at least all the generators are going to be 100% identicle this time. hho bombs are cool unless they are your hho generator and go off in your face, soaking you in lye!
Oct 17, 2008. 9:10 AMszechuan53 says:
yes, something like that happened to me once, and it was complicated slightly because it occurred in my "shed" which contained all my chemicals, tools, etc., including 5 ampoules of bromine, which were rather close to the generator. thankfully, only one broke.
Apr 1, 2008. 4:59 PMPhizicsguy says:
Michaeldnash, I read your first blot on march 13. It would be impossible to generate force in that situation, because it takes just as much force to put the projectile into the launcher as the launcher exerts on the projectile at launch. I wish it was as simple as that, but because of also the fact that the projectile would switch poles as it moves in order to align with the rings of the magnetic rings, it would doubly not work. This effect could be changed by using magnets that couldn't rotate in the tube because of there shape, but rule #one would still be in effect.
Nov 29, 2008. 8:48 AMgeeklord says:
Isn't his Idea going into the idea of an infinite energy source? Then couldn't we make a particle that goes faster than the speed of light destroying everything???? There was a movie on some genius that did that and the world about went down the toilet.
Jan 22, 2009. 10:48 PMj626no says:
in theory it would accelerate exponentially; however, eventually you'd get to a point where the magnets would just shatter because of the force.
Jan 23, 2009. 11:25 AMgeeklord says:
didn't Phizicsguy just say that it wouldn't really even move?
Jan 24, 2009. 12:21 AMj626no says:
I thought you were referring to more of a traditional gauss rifle.
Jan 24, 2009. 9:00 AMgeeklord says:
i don't really even know what a gauss rifle is except that it uses magnets to shoot things.
May 30, 2008. 7:25 PMMalifactor says:
I guess u b reffering to 1st law o thermaldynamics...forgive my spelling...I've been thinking about these strong nib mags, and I have a thaught experiment here. Imagine the Earth with its wonderful oceans...the moon wich provides the gravitational tug resulting in waves....just loaded with energy, kinetic I think. Most of us know the process. What about a magnet for the moon and a volume of dense diamagnetic fluid for an ocean...could I in effect have a perminate wave generator? I know the concept isn't practicle, but thats not the point really.
Jun 4, 2009. 7:53 AMmdgnys says:
Wow try it. submit it to NASA and tell them to make a giant magnet to send into space!
Nov 1, 2009. 5:54 AMn00b001 says:
It would work for (depending on how accurate the orbit is) a few thousand years, or maybe a few million, but by then the magnetism would have gone... And if you made it out of Iron (I think it's iron, maybe steel) and created a GIANT electromagnet (The iron holds it's magnetism when the electricity dies), and has thrusters keeping it in perfect orbit, then yes - it would stay there, as a magnet - for ever but it would take far more energy to do these things than just buy lots of water-proof bulldozers to plough the sea.
Good Luck anyway
Apr 1, 2008. 8:14 PMmichaeldnash says:
Awesome! Thanks for the info :)
Mar 17, 2008. 7:58 PMLftndbt says:
"MAGNETS ARE THE FUTURE" i've being saying this same thing for many years... The human race have two elements to help us in achieving perpectual cycles. Magnetism and gravity. If we can overcome the laws of force with the properties of magnets and gravity, we will achieve perpetual motion. It will become a reality, it's just a matter of time.
Jul 9, 2009. 1:40 AMJonny Katana says:
There are (at very least) two problems with perpetual magnet-driven generators. First, as has already been stated, all magnets wear out eventually. Being exposed to an opposing magnetic field only worsens this problem. Secondly, the law of conservation of energy is inviolable. The total lifetime energy output of a "perpetual" generator would be dwarfed by the amount of energy it took to magnetize the magnets used. Perpetual motion is not possible in this universe. This is not something against which one can use a defense like "It was once said that flight was impossible." Perpetual motion would violate several physical rules that have never been observably violated before. To put it succinctly, the laws of physics must change significantly before perpetual motion is a possibility.
Jul 9, 2009. 5:16 AMLftndbt says:
"Perpetual motion is not possible in this universe. This is not something against which one can use a defense like "It was once said that flight was impossible." Perpetual motion would violate several physical rules that have never been observably violated before." Didn't someone once say "What goes up must come down"? Tell that to the ISS astronauts. I believe the essential problem with this never ending debate is that in fact nothing last forever, except nothing. Therefore no "machine" built by man could ever last for ever. Heck the earth doesn't last for ever. So basically we need to cull the term to a really really long work machine. This has already been achieved, we just need a few more hundred years of evolution before we refine the method.
Jul 14, 2009. 11:38 PMJonny Katana says:
The ISS is planned to come down in 2020. And I'm not trying to be a jerk, but that's a totally different issue. Astronautics does not violate the laws of physics, it merely stretches our ability to supersede the obstacles they present to human technology. Overcoming the pull of gravity when you blast off in a space shuttle does not mean that gravity is a lie, it merely means you exerted enough force in an opposite direction to put yourself into orbit. But if perpetual motion was achieved, then it would throw the second law of thermodynamics completely out the window. It would prove that law outrightly false. And when everything we've seen so far has proven it categorically true, that presents a serious problem. Your claim that nothing can last forever is dead on, though. Even if perpetual motion were possible, the machine would have to be made of frictionless materials and operate in a vacuum. Neither frictionless materials nor absolute vacuum are things we have in our neck of the universe (the latter is available only in a black hole, something which usually frowns upon the orderly arrangement of matter).
Mar 17, 2008. 8:30 PMmichaeldnash says:
Sep 19, 2009. 6:41 PMgreenbean says:
You need to go to college, Mr. Toilet cleaner. LEDs are used in every stoplight in America, plus in most flashlights. Magnets are one of many ways to counter gravity. Ever seen an airplane? The only thing that uses magnets cost effectively is a levitation train. And when exactly did anyone say that a constant wouldn't be found? All of these things HAVE been done. P.S. I want my Big Mac with NO LETTUCE this time!
1-40 of 71next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Ark
