Micro Origami
Introduction: Micro Origami
as I've used aluminium foil salvaged from sweets it's not technically paper but it's as close a match as I could find.
Step 1: Master an Origami Form
learn to make a simple origami form in paper this is a pin wheel instructables on making it are available but I can't work out how to link to them.
Step 2: Salvage Your Aluminium Foil
find some sweets that are either just foil wrapped or have an easily separated foil layer. foil with a coloured or patterned side makes for a prettier end product. smooth the foil by drawing between thumb and fore finger whilst applying gentle pressure.
Step 3: Make Origami Form
use your learned fold pattern to produce a miniature item. due to the small scale I found it necessary to use tools a sewing needle for easing folds into position the edge of ca credit card to get straight creases and a match stick/tooth pick to open up layers.
Step 4: Eat Another Sweet
and make something else.
    • Paper Contest 2018
      Paper Contest 2018
    • Trash to Treasure
      Trash to Treasure
    • Pocket-Sized Contest
    Impressive! What size were your finished objects? I'd love to see something to compare it to next to it!
    In step 3 there is a coin sitting on the finnished pin wheel it is a UK 1pence coin its 20mm diameter, if you click on see all a nother image of the finnished boat appears sitting on my finger its 12mm wide and 40mm tip to tip
