Micro Rubber Band Gun
1,747
20
4
Published
Introduction: Micro Rubber Band Gun
About: I have a knack for making functional miniatures. I don't use any specialized tools or materials for making these.
smallest rubber band gun I ever built shoots small bits of wire
with a trigger mechanism and a storage box.
I have a knack for miniaturizing things.
I challenge myself to create something with minimal stuff when bored; this has led to most of my functional miniatures.
Many were built almost 7-9 years ago including this tiny rubber band gun which I found last week in a vial with chalk carvings and some other micro stuff. After replacing the rubber band it is functional again.
Has 6 individual parts, and probably took less than an hour to assemble.
The main body is rolled from a bit of thick aluminium foil to form the barrel and to hold the trigger in place.
The mechanism is similar to my  DIY rubber band gun instructable.
For the plunger, a bit of sturdy wire with a bent loop serving to hold the rubber band and to arm it has been used.
Tiny rubber bands: a thin slice from rubber tubing!
    • Creative Misuse Contest
    • BBQ Showdown Challenge
    • Oil Contest
      Oil Contest
    4 Discussions
    This is really cool, but if possible I'd like to see a step by step construction. I really dig the intricacy of working with smaller bits and bobs to make things.
    Thank you
    Will surely let you
    know, when I post a DIY tutorial
    If you have seen my other tutorial, the mechanism is almost
    the same, except for the size.
    sjroth
    4 years ago
    Wow, that is incredible! And I thought the things I make were small.
