Introduction: Minecraft Ores(no Mods, for Xbox)
a guide to minecraft ores
Step 1: Coal Ore
coal ore is the most common ore you can find.but on your first day you may not have any so smelt a wood block (not planks)
Step 2: Iron
iron can be found at level 1 or under.when smelted will turn into an ingot which can be used to make tools and armour
Step 3: Redstone
redstone can be found at the same level as diamonds , level 21 and below.It will drop 5-8 piecies of redstone.can be used like an eletric wire to make doors open automatically and anything like that
Step 4: Gold
gold is the weakest thing to make tools out of but the easiest
to enchant.can be found below level 32 used for making minecart rails,clocks and compasses.Golden swords do the same amount of
damage as a wooden sword but have worse durability
Step 5: Lapis Lazuli
lapis can be used for blue dye and can(with 9 pieces) be crafted into
a block.gives you a few pieces not just 1.found below level 32
Step 6: Diamond
diamond is the rarest but strongest ore used for tools and armour.found on level 15 and under
Step 7: Finish
hope i helped you finding ores
Step 8: Emerald
emerald ore can be found at level 11 under the extreme hills and roofed forest biomes . their only uses are villager trading and for decorative blocks
