3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
mini USB powered Tiffany Lamp
Step 9Assemble stem and LED
Poke the LED wires down the ferule from the thin end and pull through gently.
Insert the lampshade support frame and arrange them so that the LED sits nicely in the middle of the frame.
Holding the stem, the frame and the LED with a piece of tissue (it will get hot) squirt some hot melt down inside the stem to secure them. Before it sets make sure that the wire is draped over the rim of the bottom of the stem where you make your small indent.
Trim off any excess glue, making sure NOT to cut the wires by mistake.
Glue the stem to the coin base. I used Super Glue again here, but you could just as easily use two part epoxy resin.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
333
Author:KaptinScarlet(dadcando)
Eldest of five, son of two doctors, 10 years in Graphic Design and marketing, then retrained as a Biomedical Materials Engineer, don't ask me why, I think it was because I had always wanted to design ...
more »
