Mini Cheap Ac to Dc Converter
Introduction: Mini Cheap Ac to Dc Converter
my friend told me to or simply challenged me to make a converter that is easy .i can not make difficult things but this one was so easy that i made it in almost three minutes.this one was an ac to dc costed me only a few dollars.just the cost of four is very easy and no trouble for soldering. so i want to share it with you lets get started
Step 1: Ingredients
things needed:
1)four diodes of any size
tools needed:
thats all you need
Step 2: Information About Diode
diode is a electronic ingredient that helps electricity flow in one way.there are two leads one positive and other negative.onthe diode one one side there is a white coloured small band.that is the negative side of diode .a hand drawn figure of it is given below
Step 3: The Diagram of the Circuit
this is the drawing of the circuit.the circuit can be made using this diagram even easier
Step 4: The Main Circuit
firstly take the first diode and second diode and join their negative leads together.lets name this negative sides.just name.
Step 5:
now take the 3rd and 4th diode and join their positive sides together as shown,lets name this end positive end
Step 6:
now take the four diodes.there are two free ends one the first and second diode that is the two positive join these positive ends to the free negative  ends of the 3rd and 4th in the picture now lets name these ac leads
Step 7: Identifiying the Poles
the circuit is complete.the joining place that was named ac leads are the ac electricity are to be given through these two ends.the end named negative side is the positive dc output that is positive dc electricity will come out of it.and the end named positive side is the negative dc output.that is negative dc electricity will come out of your ac to dc converter is ready.have fun with it
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
  • Pocket-Sized Contest
The bridge rectifier is so useful. I work on generator control units (GCU's) that regulate generator output on aircraft and some of them use this configuration in a ground fault detection circuit. Some capacitance across the output would be helpful to keep your voltage level constant and soldering is always the best way to go but way to go to solve the ac to dc problem.
I want to make a 240v ac to 12v dc converter. Can yoy help me???
Can we run a led light script with it
This would make for a terrible dc supply. First off a transformer ia needed to drop the voltage down to a useful dc level. Some output capacitance is required to keep the output constant
Yeah, I should have added those at first. I made this when I needed to rectify ac current to Dc for my homemade generator project. So for that it worked quite well, but if you want to work with wall outlets, you of course have to change up the circuit.
wat is the output volttage??
It does not have any output voltage unless you input electricity. The only thing this circuit does is convert A.C electricity to D.C. electricity. So it would be useful only when you need to convert A.C electricity to D.D electricity for any electronics..
Should there be any specifications of the diodes if i want to convert 220v AC to 220v DC, or any diode could do?
