Introduction: Portable Prefab Playhouse
This small dome is perfect for kids and also for adults to be placed in the yard for the summer. It is also a cool play house to be placed in kids room. You can even use it as a break room inside a large office.
The laser cut pieces assemble in less than an hour and can be stored in stacks. That largest piece is 24"x18".
Step 1: Download the Dxf File
Once you download the file, you are ready to laser-cut the pieces. Next is to purchase wood.
Step 2: Lasercut or CNC Mill the Parts
once you have the file, you can start laser cutting or CNC milling the parts from 1/8" plywood (Birch is a reasonable one to use, price wise).
I used a 24"x18" laser bed so I had my wood supplier cut 4x8 sheets into 24x18 sheets.
You can use a 4x8 CNC milling bed to cut a few pieces together.
Step 3: Assembly
Buy some screws and nuts and start assembling! The holes are already cut out.
Start assembling the vertical raws. Once you have them all connected, you can attach them to the next.
To build a raw, first slide the extended parts into the cut line of the lower part (According to the images).
