Step 2How to with old cartridge
first test your cassette if you can twist the end cap around then it is the old style non crimped caps if you can twist it you can pop it off. if it cant and most wont then skip to the next step.{read this one anyway you might be able to figure out how to open a modern cassette}.
pop off one end cap
remove the reel
{if the reel inside has a slot in it then use it if not break open a newer fuji brand cartridge to use the reel from that you can still use the solid core if you want but you will have to tape your line onto it}.
tie or tape your line to the core
use your punch or a dremel to cut some windows through the main casing{sand the edges}
the reason for this is so you can see how much line is in your reel and whether its lined up evenly also to be able to load up a newer case if theres no film sticking out.
replace end cap then roll up the line move it from side to side as you wind to distribute the string evenly {if you dont do this it will all bunch up in one spot and you will only get 1/3 or so of what you can wind up with a little care}
i bought a new one last year at an obscure tool store.
then i broke it lol.
thanks for your input though :)
