Introduction: Mini Valentine Box
Picture of Mini Valentine Box
Hello everyone !! This is my 1st instructable and I am going to show you how to make a cute tiny valentine box . This is a kind of exploding box .Hope u'll like this . Please do not forget to vote for it in the purple contest ! :)
To make this valentine box , you will need :
1) Thick paper (any 2 colors of your choice )-purple & white
2) pencil
3) pair of scissors
4) craft wire
5) measuring scale
6) hot glue (or fevicol )
7) thin satin ribbon (for decoration)
8) net cloth (for decoration )
Step 1:
Picture of
Draw a square (6 cm * 6 cm ) on purple sheet and cut it out neatly . Do the same on white sheet
Step 2:
Picture of
On the purple square draw 2 lines , one at a distance of 2 cm from the left edge (of the square) & parallel to it and the other one at a distance of 4 cm from the left edge . Rotate the square by 90 degrees and repeat the procedure . Do this on white square too .If you have done it correctly , u'll see 9 small squares in the bigger square.
Step 3:
Picture of
Cut off the 4 corner small squares of both (6 cm * 6 cm ) purple and white squares . Now reduce the size of 3 edges of each of the 4 outer squares by 2 mm (as shown in pic 2 ) . Glue the white paper piece over the purple one & one they are firmly stuck lift the 4 outer squares (as shown in pic 3 ) . Using craft wire make the message u want to express :)  (as shown in pic 4 ).
Step 4:
Picture of
For decorating , we use purple paper to make flowers .
1) Draw a spiral on the sheet.
2) using a pair of scissors cut it along the spiral drawn.
3) Start rolling it from its outer end.
4) At the end , put a dab of glue and ensure it stays properly.
Make few such flowers ( I made 6 ).
Now paste the craft wire message u just made on the purple+white '+' structure . Decorate it by pasting the flowers (as shown in pic ).
Step 5:
Picture of
Now for making cap or lid , cut another 6 cm * 6 cm purple square . Mark 9 squares as done earlier .
NOTE : For lid , make sure that the centre square is larger than 2 cm * 2 cm square .
Mark the centres of outer squares & join them so that it will form a 5 cm *5 cm square ( as shown in 1 pic ).
Now holding the 6 cm *6 cm square , make a cut only at the vertical line of the bottom most left square(as shown in 2 pic ).
Now rotate it by 90 degrees & repeat the same procedure. This is done for 4 times on the whole .
Cut along the 5 cm * 5 cm square marked earlier . Keeping the the centre square as the base , lift the outer flaps up ,so that u'll get something as shown in 3 pic.
Keeping the smaller flaps inside paste them properly (as shown in 4 pic ).
Step 6:
Picture of
Now decorate the lid with satin ribbon . Place the lid on the '+' structure. Wrap it up in a net cloth and tie it on the top .
I'm sure any girl would love this :)
breebear (author)2014-02-08
Thank you! I'm here on instructables looking for Valentine's Day ideas. love this. <3
asdzahra (author)2013-06-11
accha hai:D:D:D
wow.. nice...
manuja (author)2013-04-18
Don't know why I'm not able to reply to the comment...anyways thanks a lot!! and the roses are very much fun to make :)
Muhaiminah Faiz (author)2013-04-17
It's super cute, love the tiny roses :)
About This Instructable
1,931views
56favorites
License:
Bio: hi !! I m a college going student , interested in trying out all new things with paper . I love to make paper flowers , roses & bouquets :) More »
More by manuja:Quilled paper pondmini valentine box
Add instructable to:
