M&m/ Gumball Machine
Introduction: M&m/ Gumball Machine
this is my first instructable so my cuts aren't straight
plywood but i used decking timber
a jam jar + lid
a small rectangle of timber
a drill + 20 piece drill-bit
pva wood glue
long nose plyers
a small nail
hot glue
sanding paper
Step 1: Makeing the Base
1. get to pieces of plywood the same size
2. cut to small pieces the same size
3. (optional) cut a small piece of your slide to fit in the gap. there is also one at the back.
4. when you glue no. DO NOT GLUE THE SLIDE ON! as you want to pull that out when you put the base in the vice to dry.
Step 2: The Slide Pt1
1. first you need a drill bit witch is the same size as the dowel then you drill in to slide get your piece of dowel and put pva in the hole and tap the dowel in the hole with a hamer
2. get the 20 bit and drill on both sides makeing shore you size it up first
3. get your craft knife and carve the guide out.
Step 3: The Shoot
1. get your 20 bit and drill a hole thru the top
2. get jar lid and your pliers and put a big hole in the top then glue it down with a hot glue gun
Step 4: The Nail
1. now slot the slide in to the gap and nail and fold the nail into the guide slot
Step 5: Enjoy
put your candy in the jar and twist the jar on and enjoy
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    • Pocket-Sized Contest
    I must mention that the deck lumber is not a good idea. most of it is treated with poisons to inhibit the little micro organisms that make wood rot. so Please stick with untreated and preferably new wood.
    Mmm just how i like my m&ms with poison lol. Cool will change slide
    It ok i did the sides with a grinder
    I've seen this kinda thing before but it's still a great idea. I think the only thing it needs is a bit more cleaning up, but other than that it's a great idea that's very easy to make.
    True i tried cleaning it up with grinder lol blew a fuse and court my first base on fire
