Introduction: Modified (but Still Awesome) Pea Shooter 2
Picture of Modified (but Still Awesome) Pea Shooter 2
this is my fist instructable so dont yell if its not perfect! its basically a modification of an existing constructable which i made bored as ever at skool
hope u luv it!!!
Step 1: Materials Needed:
Picture of Materials Needed:
you will need
rubber glove
bottle (small water bottle will do)
scissors
pea or similar sized round object
Step 2: Assembly
Picture of Assembly
first the neck and the curved area around it needs to be cut off the the main body of the bottle. then cut a finger (as apposed to a balloon)off the glove and stretch it as far as possible down the neck after taking off the ring that is so often on the neck (you can use this for holding on the finger of the glove while firing).
then put the ring onto the neck over the rubber (duct tape is another method 4 keeping it on if u want to be sure.
Step 3: Firing
Picture of Firing
to load, hold the shooter with the open end facing you and drop in your choice of ammunition and point the open end away from anyone within30ft of u! then gripping the projectile pull back the glove finger and ... let go! the distance you can pull back depends on how far u think u can without it snapping!
Step 4: Almost There!!!
Picture of Almost There!!!
FFFIIIIIRRRREEEEEEEE!!!!!
potez (author)2009-10-14
Hey nice stuff bro.... you mind if i use this to sell ta peeps ??? i'dlove to could make a good buck with it, good stuff  \m/
elnino (author)2008-06-17
If you use a pen lid from one of the bic pens they fly out pretty fast and are pretty sore. I agree with supersaddy just push the glove finger threw the hole to the other side and it works better. I dont see the point of the plastic bit no more which looks like a shield, so i cut it off and no just have the screwy bit of the bottle.
and63 (author)2008-02-16
i love cheese
supersaddy (author)2007-11-12
i tried putting the balloon/glove through the other side after it is attached ( see picture). So when you let go there is no chance the bb will get stuck in the balloon by the lid because the balloon goes right through to the other side sending the bbs flyin
!Andrew_Modder! (author)2007-11-12
not bad. but dont use peas, use airsoft bbs (there really cheap of a @$$ load of them :-)
iKill (author)2007-11-12
so only thing that is different is used the standard thing on the neck instead of a rubber band or something similar?
About This Instructable
3,914views
3favorites
License:
More by $$$nico$$$:modified (but still awesome) pea shooter 2super fun exploding hammer
Add instructable to:
