Introduction: Modified Camera Battery-compartment Clasp
Picture of Modified Camera Battery-compartment Clasp
this camera's two AA batteries over time had worn away the clasp that held the door closed. amongst other things i tried making a new clasp by heat welding a plastic strip from an id card into the door. it was kind of like a mortise and tenon joint but failed due to forces from the batteries wanting to push out.
so i came up with a longer strip that i could buckle under the camera strap mount.
anyway the pictures will speak their thousand words and explain more clearly!
Phil B (author)2012-11-14
You have a good solution to a fairly common problem. I guess we are all supposed to buy a new, more expensive camera. My wife's first camera has this problem. I considered making a steel plate the length of the camera's bottom, drilling a hole to match the 1/4 x 20 tripod socket, and inserting a cap screw. She never used the tripod socket, anyway. But, she wanted a better camera with less shutter lag so she could get better pictures of fast-moving grandchildren.
About This Instructable
494views
0favorites
License:
Bio: i make, mend and modify things from rubbish, whether found or donated, whilst travelling around these islands off the coast of europe
More by man-of-light:modified camera battery-compartment claspweb cam mount for wider objectswind powered wicker basket led light
Add instructable to:
