so, i was fed up of the jacks in my xrocker chair breaking and only giving me mono audio. i had tried replacing them with brand new ones only to have them break on me a month or so later. so i said to myself what plug is simple, reliable, can be extended easily and i have lots of.... USB! so i set out to fix my chair with the wonders that is the USB port!
this can be done relatively easily with a little soldering knowledge, some patience!
(has been tested with cables over 2m in length!
Disclaimer!
i am not responsable for your actions. if YOU mess up following these instructions. it is entirely your fault and i take 0% responsibility.
now we got that over, lets continue!
Remove these ads by
Signing UpStep 1: Open that baby up!
you must remove the amplifiyer in the chair. there is 5 screws holding it in place. simply undo these and it will slide out.
now there will be two small wires doing to the speakers at the back. give em a tug and they will just come out.
put it face down and there will be two holes at either side. there are two screws down these holes and they are quite deep. use a long + screwdrive to take them out.
after this there will be two small tabs on the lower side stick a small screw driver in one and give it a yank and the other one will pop out. then just slide it off...
to take the faceplate off, you will need to undo some screws on the power button and the light bit. and take the volume handles and small bolts underneath off.
Not Nice
Visit Our Store »
Go Pro Today »
