You can purchase a fully assembled monoXover from me here.
Features:
- 2-way 2nd-order crossover (ie, it can be used with any speaker that has a woofer and a tweeter)
- compact low cost design using easily available parts
- easy to adjust the crossover frequency
- adjustable equalizer for the woofer and tweeter
- can convert stereo to mono, or can select either left or right channel only
- published design you can use and modify as needed
Remove these ads by
Signing UpStep 1How it works
the input jack is on the left and the output jack on the right. the headers above the circuit explain what each section does.
If you want the stereo-to-mono function, install both R3 and R4. if you want just the left channel or the right channel, install just one of them.
The relative output volume for the woofer and the tweeter is set by the pots R6 and R7
.... and R8 is controlling Left Channel (Ch2,Woofer,White): CounterClockwise (maximum).
I tried the monoXover to both a Sure Electronics TA2024 (http://www.parts-express.com/pe/showdetl.cfm?Partnumber=320-308) and a smaller 16 watt Sure Amp,
(http://www.parts-express.com/pe/showdetl.cfm?Partnumber=320-310)
Can you confirm this? thanks,
hook up just the woofer first. put your ipod volume fairly low. turn both dials (R7/R8) until it is as loud as it gets and you know which dial is controlling it. play something with a low, heavy beat - do you hear the beat? if not then you got the woofer on the tweeter channel. now you know which channel is which, put the woofer on the correct channel. the woofer will also be way louder on the correct channel. set the woofer's dial to maximum. now hook up the tweeter. adjust its dial until things sound ok - on all the speakers i tried the tweeter dial is set at about 50% to get good equalization.
Cool 'Ible!
