monster yet efficient and simple joule thief
Hi,every one Im shams and this is my first instructable but im not new on instructables.hope you will enjoy.....
This is da one and only the famous circuit we all know as joule thief.it is a blocking osc.In some site people say it can produce votage from 3-6 volt.But they r wrong it produce 40+ volt not kiddin.u will need a digital multi meter to see it.My joule thief can operate from 0.5 volt in single cell mode but it needs above0.9 volt in monster mode.In this mode you can run 6leds on aa and 8 leds on d cell.And i know ur al thinkin that im jokin cuz 40 volt will fry the leds right? so for the answer check this url :http://www.talkingelectronics.com/projects/LEDTorchCircuits/LEDTorchCircuits-P1.html.
Step 1Tools and parts
tools and parts
Now go to ur junk box and search for this parts.
1.bread board(for testing)
2.leds any brght led(white,blue,uv)
3.toroid core(big one for power smaller one for mobility)
4.resistors(from 50R-2k ohm)
5.2n2222.(for single led and super efficency)
6.bd 135(medium-low power)
7.tip 32(high power)
8.tip 3055 or 2n3055(monster power.tip 3055 is better cuz it is smaller than his bro)
9.a zener diode (cuz it got lower voltage drop)
10.10-20uf cap (50volt is good for the circuit)
11.one battery (button cell=mobility,aaa=mobility,aa=power,d=highpower)
12.jumper wire
13.28no super enamel coated wire(magnet wire)
14.mosfet (not tested but it should work)
49 comments
1-40 of 49next »
Oct 14, 2008. 10:30 AMadmin says:
This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
Dec 18, 2010. 10:48 AMjomac_uk says:
Another Circuit Shams stolen off the internet, this time it was taken from Colins site www.TalkingElectronics.com in Australia. You are just a thieving pretender Shams, you take other peoples hard work, and pass it off as your own, but this time ive emailed instructables, and ive sent an email to colin as well, with a link to this project so he can see how his hard work has been stolen....you dont even have the manners to acknowledge the work that you steal, is someone elses, you just pretend its your own
Dec 19, 2010. 7:10 AMjomac_uk says:
YES...you did steal it, it clearly says on the cappels site, that everything is copyright (c) It ALSO says that you CANT use any material WITHOUT the owners consent!!
You just cut and pasted someone elses work WITHOUT their permission, and YES it is THEFT
Why are we after you, as you put it? because you are a THIEF of other peoples work, probably incapable of designing your own!!...and yes there are a few of us now that will be following your future work to make sure its not been stolen from someone else!!!
Dec 18, 2010. 7:10 PMDick Cappels says:
I hope that in the future, Instructables shows the courtesy of asking copyright holders for permission to use copied material.
The web page on my site that sorts out a lot of the details and contain tips to debug the circuit:
http://cappels.org/dproj/ledpage/leddrv.htm
Aug 15, 2010. 12:41 AMazthinks says:
Not bad for a 14-year-old! But I can tell just by looking... that is waay too many windings on the toroid to be efficient. Longer wires have higher resistance. Even just 5-10 turns should be OK. And try thicker wire to lower the resistance. Check out http://azthinks.com/JT_resources.html for more joule thief hints.
Sep 2, 2009. 1:24 AMacmefixer says:
Lotta confusion here. Two different schematics, 3055 is not used here. The second schematic shows a 10n capacitor, but I've tried this circuit and it works without the cap, but goes dim when I add the cap. I recommend not to use it.
Dec 12, 2009. 4:14 PMacmefixer says:
The number of turns I use depends on the core material.  I try to keep the inductance of each winding at least 100 microhenrys.  Some cores are low mu (permeability) and need at least 20 to 30 turns.  Some high mu cores only need 5 to 8 turns.  See my blog here for some of the cores I use.  And here is a higher power supercharged JT I built last week using some new stuff I bought.
Keep the resistance of the toroid windings low.  Your JT will lose brightness if it is too high.    If you can measure it with a cheap DMM, a half ohm for instance, then it is too much.  Heavier wire helps, too.  You can wind the core with a second or third primary winding and connect the two or three windings in parallel.
As for substituting the 2N3055 for the 2N4401, you will have to do more than that.  The 2N4401 has a gain of several hundred, the 2N3055 is lucky to have a gain of 100.  If you leave the resistor at 1000 ohms, then the 2N3055 will conduct less than a third of the current of the 2N4401.  You have to allow more base bias current by lowering the resistor to 330 ohms or maybe less.
Have fun.  Best of success in building your Joule Thief.
Apr 12, 2009. 7:03 AMbuild a BOOM says:
I see that U are using old telephone wire. I used that stuff all the time, after I got a 3 foot section from a garbage can. It had over thirty, yard long wires.
Mar 17, 2009. 5:15 AMxombie88 says:
Great instructable, but you could improve the language. A lot.
Mar 17, 2009. 12:38 PMxombie88 says:
Well, look at your comment section. Your English here is excellent. But in the article you haven't bothered to write most words in their full forms :p
Jan 5, 2009. 8:32 AMuberdum05 says:
After I wound it as well, the circuit did'nt work!!(Curse you....circuit =))
Jan 6, 2009. 9:40 AMuberdum05 says:
Im using a TIP31A, reading the datasheet it says it needs something like 350 Ma to turn on, maby its too much?
Jan 10, 2009. 1:57 AMuberdum05 says:
It needs 5 volts to turn on, also what GPU make is your new one?
Jan 12, 2009. 7:50 AMuberdum05 says:
would a darlington pair work well?
Jan 13, 2009. 9:23 AMuberdum05 says:
it's a pain in the butt. I'm more used to building logic circuits with HCF4xxxBEY IC's and using computers.I have currently got an ICT job off my ICT manager, its awesome.
Jan 4, 2009. 2:33 AMuberdum05 says:
I got the stripped end of the wire stuck in my finger... OUCH
Jan 4, 2009. 2:53 AMuberdum05 says:
Will a TIP31A do??
Nov 29, 2008. 11:24 AMSubconscionaut says:
Yr a totl Gnyuss bt itz knda hrd 2 Unrstnd wht U R. sying. Mebbe U cn take it EZ on sum f s OLD folkx?(mid-30's) Thnx. BTW Great Idea!
Nov 22, 2008. 2:26 PMjunits15 says:
it is a little dangerous to be putting you're age at the end like that, anybody can see it. so I've heard from the evil mad scintist version if this that the wires cant cross in the torroid. is that true? (if you know)
Nov 25, 2008. 12:48 PMjunits15 says:
lets say i use two diffrent colored wires for the it,that no two wires of the same color could be next to each other, but it dosn't matter because i got it to work! :D
Nov 12, 2008. 2:09 AMriddimdon says:
great job shams!
Oct 28, 2008. 2:18 PMDigital_Anarchy says:
do you wanna try listening in english as well as science. This istructable is very interesting but nigh on unreadable.
1-40 of 49next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:shams
