This is da one and only the famous circuit we all know as joule thief.it is a blocking osc.In some site people say it can produce votage from 3-6 volt.But they r wrong it produce 40+ volt not kiddin.u will need a digital multi meter to see it.My joule thief can operate from 0.5 volt in single cell mode but it needs above0.9 volt in monster mode.In this mode you can run 6leds on aa and 8 leds on d cell.And i know ur al thinkin that im jokin cuz 40 volt will fry the leds right? so for the answer check this url :http://www.talkingelectronics.com/projects/LEDTorchCircuits/LEDTorchCircuits-P1.html.
Remove these ads by
Signing UpStep 1Tools and parts
1.bread board(for testing)
2.leds any brght led(white,blue,uv)
3.toroid core(big one for power smaller one for mobility)
4.resistors(from 50R-2k ohm)
5.2n2222.(for single led and super efficency)
6.bd 135(medium-low power)
7.tip 32(high power)
8.tip 3055 or 2n3055(monster power.tip 3055 is better cuz it is smaller than his bro)
9.a zener diode (cuz it got lower voltage drop)
10.10-20uf cap (50volt is good for the circuit)
11.one battery (button cell=mobility,aaa=mobility,aa=power,d=highpower)
12.jumper wire
13.28no super enamel coated wire(magnet wire)
14.mosfet (not tested but it should work)
You just cut and pasted someone elses work WITHOUT their permission, and YES it is THEFT
Why are we after you, as you put it? because you are a THIEF of other peoples work, probably incapable of designing your own!!...and yes there are a few of us now that will be following your future work to make sure its not been stolen from someone else!!!
I hope that in the future, Instructables shows the courtesy of asking copyright holders for permission to use copied material.
The web page on my site that sorts out a lot of the details and contain tips to debug the circuit:
http://cappels.org/dproj/ledpage/leddrv.htm
Keep the resistance of the toroid windings low. Your JT will lose brightness if it is too high. If you can measure it with a cheap DMM, a half ohm for instance, then it is too much. Heavier wire helps, too. You can wind the core with a second or third primary winding and connect the two or three windings in parallel.
As for substituting the 2N3055 for the 2N4401, you will have to do more than that. The 2N4401 has a gain of several hundred, the 2N3055 is lucky to have a gain of 100. If you leave the resistor at 1000 ohms, then the 2N3055 will conduct less than a third of the current of the 2N4401. You have to allow more base bias current by lowering the resistor to 330 ohms or maybe less.
Have fun. Best of success in building your Joule Thief.
