3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
monster yet efficient and simple joule thief
Step 2Winding the transformer(inductor)
winding the transformer(inductor)
Now come to the heart of this thing.u can use a ferrite rod if u wish.But it needs 4X turns to achive the power and the magnetic flux leaks from the two end but toroid is ring shaped so and all the flux is in the center so Less than 1% is wasted.
Some people say it is da most tricky part but it simple as kniting a shirt.u can find small cores in cfl bulbs,big cores in psu on ur pc,u can also buy them like me.in my country it cost 8 tk it mean 0.05cent only .
WINDING:i cant show my winding proces cuz i ve wind it.and it took me about 3 days to do it .i did in my class,my home also in toilet.LOL.there is two types winding.1.wind to wire together like ive done in the picture 2. center tap winding.The first one is easy cuz when ur winding 80 turns u only need to wind it 80 turns but in the second one u have to wind 160 turns.i am giving the urls of windings.
1.http://www.evilmadscientist.com/article.php/joulethief
2.http://www.cappels.org/dproj/Toroid_winding/Toroid_Winding.html
now my core has 100 turns of wire but u cant turn them like on the urls with only hand.here is the trick ,get a thick jumper wire(magic wand) and wind 5 meter of wire on it.then take out 10cm of wire then wind the toroid like u r sewing a cloth.first place the wand under the toroid and then take it out from the center and again take the wand to the bottom of the toroid and take it out from the center.u should stick a tape on the starting point cuz without it the wire will be loose.when u ve done it in anti clockwise and ur winding has come to the starting point get a transperant tape (very thin one).go round the core about two times with the tape.now start winding again with the same wire and continue this task until all the wire is finish.the tape is not necessary.it is only for neat winding.connect the two wire like it has done on the site of evil mad scientist.
dont worry i will upload a video on youtube for winding.
P.S 100 turns wire is for big core.and 20 turns for small core.big core is for more leds.but small core from ccfl is only for two leds
15 comments
Aug 15, 2010. 12:41 AMazthinks says:
Not bad for a 14-year-old! But I can tell just by looking... that is waay too many windings on the toroid to be efficient. Longer wires have higher resistance. Even just 5-10 turns should be OK. And try thicker wire to lower the resistance. Check out http://azthinks.com/JT_resources.html for more joule thief hints.
Jan 5, 2009. 8:32 AMuberdum05 says:
After I wound it as well, the circuit did'nt work!!(Curse you....circuit =))
Jan 6, 2009. 9:40 AMuberdum05 says:
Im using a TIP31A, reading the datasheet it says it needs something like 350 Ma to turn on, maby its too much?
Jan 10, 2009. 1:57 AMuberdum05 says:
It needs 5 volts to turn on, also what GPU make is your new one?
Jan 12, 2009. 7:50 AMuberdum05 says:
would a darlington pair work well?
Jan 13, 2009. 9:23 AMuberdum05 says:
it's a pain in the butt. I'm more used to building logic circuits with HCF4xxxBEY IC's and using computers.I have currently got an ICT job off my ICT manager, its awesome.
Jan 4, 2009. 2:33 AMuberdum05 says:
I got the stripped end of the wire stuck in my finger... OUCH
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:shams
