3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
monster yet efficient and simple joule thief
Step 3Putting it all together
putting it all together
Now take the bread board and put the parts as shown in the pic.put 10uf cap as shown in the first pic and the 22 nf cap as shown in the second pic.put higher rating resistor for lower power and more battery life.before puting it all together search the google for its pinout.example:tip 3055 datasheet.if u r lookin for 3055 pinout
8 comments
Dec 18, 2010. 10:48 AMjomac_uk says:
Another Circuit Shams stolen off the internet, this time it was taken from Colins site www.TalkingElectronics.com in Australia. You are just a thieving pretender Shams, you take other peoples hard work, and pass it off as your own, but this time ive emailed instructables, and ive sent an email to colin as well, with a link to this project so he can see how his hard work has been stolen....you dont even have the manners to acknowledge the work that you steal, is someone elses, you just pretend its your own
Dec 19, 2010. 7:10 AMjomac_uk says:
YES...you did steal it, it clearly says on the cappels site, that everything is copyright (c) It ALSO says that you CANT use any material WITHOUT the owners consent!!
You just cut and pasted someone elses work WITHOUT their permission, and YES it is THEFT
Why are we after you, as you put it? because you are a THIEF of other peoples work, probably incapable of designing your own!!...and yes there are a few of us now that will be following your future work to make sure its not been stolen from someone else!!!
Dec 18, 2010. 7:10 PMDick Cappels says:
I hope that in the future, Instructables shows the courtesy of asking copyright holders for permission to use copied material.
The web page on my site that sorts out a lot of the details and contain tips to debug the circuit:
http://cappels.org/dproj/ledpage/leddrv.htm
Sep 2, 2009. 1:24 AMacmefixer says:
Lotta confusion here. Two different schematics, 3055 is not used here. The second schematic shows a 10n capacitor, but I've tried this circuit and it works without the cap, but goes dim when I add the cap. I recommend not to use it.
Dec 12, 2009. 4:14 PMacmefixer says:
The number of turns I use depends on the core material.  I try to keep the inductance of each winding at least 100 microhenrys.  Some cores are low mu (permeability) and need at least 20 to 30 turns.  Some high mu cores only need 5 to 8 turns.  See my blog here for some of the cores I use.  And here is a higher power supercharged JT I built last week using some new stuff I bought.
Keep the resistance of the toroid windings low.  Your JT will lose brightness if it is too high.    If you can measure it with a cheap DMM, a half ohm for instance, then it is too much.  Heavier wire helps, too.  You can wind the core with a second or third primary winding and connect the two or three windings in parallel.
As for substituting the 2N3055 for the 2N4401, you will have to do more than that.  The 2N4401 has a gain of several hundred, the 2N3055 is lucky to have a gain of 100.  If you leave the resistor at 1000 ohms, then the 2N3055 will conduct less than a third of the current of the 2N4401.  You have to allow more base bias current by lowering the resistor to 330 ohms or maybe less.
Have fun.  Best of success in building your Joule Thief.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:shams
