Step 8: The strings
1. I accidentally deleted the first pic but you can see in the first what to do
2. build the parts
3. build more
4. put the weals on first
5. put the string guards on
the ram uses the 25 inch peace of string
1.put the string on the ram through the hole then weave through the next hole that you cant fit a rod through then ty a knot so it lands in the place where you put the rubber bands on.
2.ok now slide it through the spacered rod.
3.slide it through the spacered rod again.
now knot up the end of the string so you have a bit of a handle ,but be care full not to knot it up to much or it will get to short and you will have a prob.
the trigger string you need 22 inches. it will give you a little left over to make knots on the trigger and real trigger.
1.the string should look this long near the gun
2.tie it to the trigger
3.break of the string guards and put the string in this position.
4.put the string guards back on.
5.tie it to the trigger make shure it will be tight enough to shoot the gun
Remove these ads by
Signing Up
Not Nice
Visit Our Store »
Go Pro Today »
