Make some simple moss bombs to throw at buildings and add some living green to your urban cement-scape.
Step 1: Find your moss
Moss can be found in all sorts of corners. I found mine near an abandoned pool. You can also find it online, though expensive, at mossacres.com
low-key lysmith says: Apr 9, 2013. 4:58 PM
why the paint?
Mr. Deeds says: Jan 19, 2008. 9:50 PM
Interesting. I don't suppose you could put large quantities of this in buckets and use it as a paint of sorts? I personally like the idea of moss painting.
Madrigorne in reply to Mr. DeedsNov 11, 2012. 8:35 AM
yes indeed you can :)
kikiclint in reply to Mr. DeedsJul 13, 2009. 6:30 PM
I would leave the paint out of the mix if using it as an actual paint.
waynevanwijk says: Apr 5, 2010. 10:05 PM
The easy way to fill the balloon without getting a mouthful of mossy beer would be to add the contents to a bottle that has not been cut or punctured in any way.
Then blow up the balloon to the desired size, twist the neck a few times to stop the air escaping and then stretch the neck of the balloon over the bottle opening. The balloon will stay inflated.
Turn the whole lot upside down and the contents of the bottle will fall into the balloon. Remove the still inflated balloon and tie it off.
I figured out this method whilst making about 300 balloon and birdseed style juggling balls. In fact, I should make an instructable of this.
Madrigorne in reply to waynevanwijkNov 11, 2012. 8:33 AM
You just taught me how to make my own juggling balls! That's awesome!
spark master says: Dec 5, 2011. 8:54 AM
This is ludicrous, moss may be pretty , but it ruins cement. Your paint filled moss bombs look quite disgusting, But perhaps you need the world to look like vomit or diarrhea. Do this in your bed room, sure to impress mummy and dada.
Consider getting your cities to make more green space parks and kill people who destroy them.
Oh BTW , in the summer, since I was maybe 8, we city kids would have water balloon fights. My parents (et al), would flip if we ran the hose too much. We filled a big bucket with water, from it we filled glass soda bottles, (lord I am ancient), we simply inflated the balloon and pulled it (carefully ) over top of a water filled soda bottle to just below crown (no screw tops) then holding the balloon on the neck , inverted them.
Air goes up, liquid goes down. Never had an issue. After 2-3 never lost a balloon. If you want way more air then only put a little sludge water, whatever, and fill the balloon a tad past where you want it. (Newbies will loose air till they get it right)
In later years plastic bottle made it easier, faster too since then they had half gallon bottles.
mpikas says: Dec 4, 2011. 2:51 PM
Not a great idea, some mosses and some of the things you'll find with them (mushrooms) can make you pretty sick in pretty small quantities. If you want to get the balloon fuller and pop better just put it over a water faucet or hose nozzle and top it off with some water, that will work better than air and is much safer.
mpikas says: Dec 4, 2011. 2:48 PM
You're pretty much just adding something for the moss spores to use as fuel, I've never tried sugar but I've done bread and water or bred and beer, both worked about the same. I usually add them in the previous step in the blender to mix/cut everything up well.
j574sbi says: Jul 11, 2009. 12:32 PM
i'm thinking mortar and pestle might be safer and also not ruin my grinder.
mpikas in reply to j574sbiDec 4, 2011. 2:45 PM
mortar and pestle won't work, you're not so much grinding it as cutting it up/blending it.
spectacular says: Oct 25, 2011. 10:59 PM
That. Looks. Disgusting. Haha the paint makes it look like blood (!)
ilpug says: Jul 29, 2011. 3:52 PM
http://www.instructables.com/id/The-balloon-bomb-filling-device/
i made a filling device for these. pretty simple and makes it a lot easier and cleaner.
wilson.joe says: May 25, 2008. 8:05 AM
now if there was just a way of getting up on the statue of liberty and getting some moss to grow under her nose... :)
lipase in reply to wilson.joeJul 10, 2011. 8:25 AM
http://www.play.com/Gadgets/Gadgets/4-/172541/Wild-Sling-Waterbomb-Catapult/Product.html?_%24ja=tsid:11518|cat:172541|prd:172541
bowmaster in reply to wilson.joeJun 12, 2008. 9:13 PM
Helicopter.
thermoelectric in reply to bowmasterJun 30, 2008. 10:21 PM
lol
naruto the ninja13 says: Apr 5, 2010. 6:10 PM
how  much moss do you need per beer can?
uldron says: Nov 19, 2009. 6:58 PM
THe easier way for this is to get a straw and blow into the straw. it inflates the baloon and no mess in mouth,
cambigfoot in reply to uldronJan 2, 2010. 8:34 PM
or bike or basketball pump
rockgod57 in reply to cambigfootApr 5, 2010. 1:16 PM
ya thatll probly work better
danyforreal says: Mar 6, 2010. 7:34 PM
I would advise against blowing into the balloons with your mouth after it's had the moss in them. Couldn't you just use water balloons? I think a soap pump dispenser may give enough pressure to inflate the balloons so that you don't even have to blow any air into them after wards. I've seen Martha Stewart use unflavored yogurt and moss in the blender. But my question is how soon do you have to use the bombs before they go bad or start to explode or stink or rot or whatever? I'm thinking about making a ton of these to explode onto our art center walls.
danyforreal in reply to danyforrealMar 6, 2010. 7:37 PM
You could also fill an empty squeeze bottle (like the ones for squeezable ketchup) with the mixture all the way. attach the balloon around the tip of the bottle and simply squeeze the bottle to fill the balloon.
yellowexample says: Mar 6, 2010. 9:22 AM
 You could probably use a bike pump to inflate the balloons if you didn't want to do it with your mouth.
Kim-CheapKidzClothes says: Dec 15, 2007. 10:07 PM
Is there another way to grow moss? I actually don't drink beer and the thought makes me gag. I have a very strange home and one side has a dog house looking space for the generator. The rest of that floor is the garage. I've painted the generator compartment and want moss to cover the concrete. I've never tried to grow it but was going to actually paint it when I had the time. Thanks
yellowexample in reply to Kim-CheapKidzClothesMar 6, 2010. 9:21 AM
 Well, according to sciphii's instructable (www.instructables.com/id/River-in-a-Jar/), buttermilk and sugar will raise the acidity to the point that will make moss grow.
nutsandbolts_64 in reply to Kim-CheapKidzClothesJan 31, 2010. 5:26 AM
 Are you trying to camouflage your generator compartment. Hey cool! Home grown camouflage!!
nutsandbolts_64 says: Jan 31, 2010. 5:21 AM
 I just read Berkin's comment. Then, I said to myself, "So you can actually *grow* explosives in your lawn". Kinda' funny if you think about it.
Mamohau says: Jan 21, 2010. 7:31 AM
Moss painting & sculptures which should interest you!  do some searches on those key words...
http://www.apartmenttherapy.com/sf/how-to-paint-moss-designs-in-your-garden-077167
animecello says: Dec 20, 2009. 4:51 PM
these are cool
uldron says: Nov 19, 2009. 6:59 PM
it would be neat to see the result
knex_mepalm says: Aug 25, 2009. 5:37 AM
i am not blowing on somehting thata has moss in it, you know that if moss gets into your lungs you can get an infection from them growing and have a 95% chance of dying
d2j5 says: Mar 3, 2009. 1:19 PM
thats cool, i know that milk will work as a fertilizer aswell, im not shure how good it might be getting tossed at stuff but the milk does work.
bobwantzanapple in reply to d2j5Jun 19, 2009. 1:48 PM
buttermilk is better
d2j5 in reply to bobwantzanappleJun 22, 2009. 5:17 AM
really? i never thought it would make a difference but i have used just normal milk and it works fine
Mark Drees in reply to d2j5Aug 11, 2009. 4:36 PM
It's more acidic which helps the moss grow...
Vulcanator says: Apr 24, 2009. 6:40 AM
post pics of the moss after it has grown
red devil 2 says: Jun 24, 2008. 5:13 AM
it was fun making the moss bomb but you must use paint
Berkin in reply to red devil 2Nov 20, 2008. 8:36 AM
You can make explosives out of dried moss powder called lycopodium or something of the sort.
splnlss (author) in reply to BerkinNov 20, 2008. 9:13 AM
Woah, any more info moss powder??? that sounds great!
Berkin in reply to splnlssNov 21, 2008. 6:55 AM
Yeah, you could try the wiki for lycopodium.
http://en.wikipedia.org/wiki/Lycopodium
That will tell you a lot about lycopodium, its uses, and which species of moss to get it from. You can also buy it in some places (online).
Brainiac Science Abuse has a show called "Dr.Bunhead". In one episode on April Fools Day, Dr.Bun sprinkled lycopodium powder in his friend's light fixture. When he turned it on, the whole thing burst into flames and destroyed the bulb along with it.
(Note: If you find 2 of this comment in your inbox, it's because I had to fix a minor spelling error.)
Sebastopol Plantman in reply to BerkinFeb 23, 2009. 2:46 PM
It's actually the spores of the club moss (Lycopodium), and collecting the spores will take a LONG time, unless you have a seriously large stand to collect from (or unless you can buy it). It's what they used for flash photography (remember the period shows where a person would be looking through the camera and holding a short pole with a platform on top of it...he'd trigger the camera, and the powder--on top of the platform--would flash: that's one of the powders they used for the flash.)
UltraMagnus says: Jul 30, 2008. 11:44 AM
pics showing it worked or it doesn't....
llondon says: Apr 16, 2008. 6:51 PM
Please, please show pictures of the finished product (growing moss), amazing idea. Nature art could be a big thing on city walls =). +1
Patrik says: Apr 16, 2008. 6:17 PM
Nice idea! I just wonder how well the beer+sugar works as a moss fertilizer. Or for that matter, how well the moss tolerates acrylic paint (probably fairly inert, but it may block sunlight). Since you made these last year, could you give us a quick update on how well the moss did on your "targets"?
splnlss (author) says: Mar 23, 2008. 2:59 PM
oh nice idea! I think i'll try it again this spring with yoghurt and definitly without the paint.
dustin_grey says: Mar 23, 2008. 12:53 PM
If you substitute the beer with buttermilk or yogurt it will also work, I believe. But this seems very very interesting... it's about time to make a city beautiful. Great idea, sir.
LIVINGDEAD247 says: Nov 2, 2007. 6:09 PM
It would be great to stencil the virgin mary all over it would be a mirical. where can I find a stencil of virgin mary? The moss needs moisture like next to drain pipes or fountains.
connorcancount! says: Jul 31, 2007. 12:04 PM
post some pictures of the moss grown!
porkdemon says: Jun 22, 2007. 8:34 AM
so the moss acts as the medium with the beer and the sugar as the fuel to make the moss grow? ingenious, i made a moss like slurry for a experiment once, i saw them do it on mythbusters and i thought hey that looks cool, now i sort of realise why it didnt really work, they needed food, i must try this again with a fertelizer or something mixed in.
sgt.peanut95 says: May 8, 2007. 2:10 AM
i bet u could make a stencil of some kind and make a art work on ur wall
joeny1980 says: Apr 29, 2007. 8:25 PM
I dont really get the paint either, is there a real reason for it? is it maybe so that this binds to the surface you throw it at? nah... couldnt be. And this instructable was posted on April 17th, there should be some moss a-sprouting right about now? show us some follow-up pics, otherwise i dont buy that this will actually work.
alagahd says: Apr 27, 2007. 1:00 PM
Does this instructable require the paint? Wou'ldn't the moss be more stealthy (and less likely to be cleaned off or painted over) if you didn't use the paint?
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
