3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
moss bombs
moss bombs
  • last photo ←
Make some simple moss bombs to throw at buildings and add some living green to your urban cement-scape.
Step 1Find your moss
find your moss
Moss can be found in all sorts of corners. I found mine near an abandoned pool. You can also find it online, though expensive, at mossacres.com
50 comments
1-40 of 50next »
Dec 5, 2011. 8:54 AMspark master says:
This is ludicrous, moss may be pretty , but it ruins cement. Your paint filled moss bombs look quite disgusting, But perhaps you need the world to look like vomit or diarrhea. Do this in your bed room, sure to impress mummy and dada.
Consider getting your cities to make more green space parks and kill people who destroy them.
Oh BTW , in the summer, since I was maybe 8, we city kids would have water balloon fights. My parents (et al), would flip if we ran the hose too much. We filled a big bucket with water, from it we filled glass soda bottles, (lord I am ancient), we simply inflated the balloon and pulled it (carefully ) over top of a water filled soda bottle to just below crown (no screw tops) then holding the balloon on the neck , inverted them.
Air goes up, liquid goes down. Never had an issue. After 2-3 never lost a balloon. If you want way more air then only put a little sludge water, whatever, and fill the balloon a tad past where you want it. (Newbies will loose air till they get it right)
In later years plastic bottle made it easier, faster too since then they had half gallon bottles.
Dec 4, 2011. 2:51 PMmpikas says:
Not a great idea, some mosses and some of the things you'll find with them (mushrooms) can make you pretty sick in pretty small quantities. If you want to get the balloon fuller and pop better just put it over a water faucet or hose nozzle and top it off with some water, that will work better than air and is much safer.
Dec 4, 2011. 2:48 PMmpikas says:
You're pretty much just adding something for the moss spores to use as fuel, I've never tried sugar but I've done bread and water or bred and beer, both worked about the same. I usually add them in the previous step in the blender to mix/cut everything up well.
Jul 11, 2009. 12:32 PMj574sbi says:
i'm thinking mortar and pestle might be safer and also not ruin my grinder.
Dec 4, 2011. 2:45 PMmpikas says:
mortar and pestle won't work, you're not so much grinding it as cutting it up/blending it.
Oct 25, 2011. 10:59 PMLivStoleYourPie says:
That. Looks. Disgusting. Haha the paint makes it look like blood (!)
Jul 29, 2011. 3:52 PMilpug says:
http://www.instructables.com/id/The-balloon-bomb-filling-device/
i made a filling device for these. pretty simple and makes it a lot easier and cleaner.
May 25, 2008. 8:05 AMwilson.joe says:
now if there was just a way of getting up on the statue of liberty and getting some moss to grow under her nose... :)
Jul 10, 2011. 8:25 AMlipase says:
http://www.play.com/Gadgets/Gadgets/4-/172541/Wild-Sling-Waterbomb-Catapult/Product.html?_%24ja=tsid:11518|cat:172541|prd:172541
Jun 12, 2008. 9:13 PMbowmaster says:
Helicopter.
Jun 30, 2008. 10:21 PMthermoelectric says:
lol
Apr 5, 2010. 10:05 PMwaynevanwijk says:
The easy way to fill the balloon without getting a mouthful of mossy beer would be to add the contents to a bottle that has not been cut or punctured in any way.
Then blow up the balloon to the desired size, twist the neck a few times to stop the air escaping and then stretch the neck of the balloon over the bottle opening. The balloon will stay inflated.
Turn the whole lot upside down and the contents of the bottle will fall into the balloon. Remove the still inflated balloon and tie it off.
I figured out this method whilst making about 300 balloon and birdseed style juggling balls. In fact, I should make an instructable of this.
Apr 5, 2010. 6:10 PMnaruto the ninja13 says:
how  much moss do you need per beer can?
Nov 19, 2009. 6:58 PMuldron says:
THe easier way for this is to get a straw and blow into the straw. it inflates the baloon and no mess in mouth,
Jan 2, 2010. 8:34 PMcambigfoot says:
or bike or basketball pump
Apr 5, 2010. 1:16 PMrockgod57 says:
ya thatll probly work better
Mar 6, 2010. 7:34 PMdanyforreal says:
I would advise against blowing into the balloons with your mouth after it's had the moss in them. Couldn't you just use water balloons? I think a soap pump dispenser may give enough pressure to inflate the balloons so that you don't even have to blow any air into them after wards. I've seen Martha Stewart use unflavored yogurt and moss in the blender. But my question is how soon do you have to use the bombs before they go bad or start to explode or stink or rot or whatever? I'm thinking about making a ton of these to explode onto our art center walls.
Mar 6, 2010. 7:37 PMdanyforreal says:
You could also fill an empty squeeze bottle (like the ones for squeezable ketchup) with the mixture all the way. attach the balloon around the tip of the bottle and simply squeeze the bottle to fill the balloon.
Mar 6, 2010. 9:22 AMyellowexample says:
 You could probably use a bike pump to inflate the balloons if you didn't want to do it with your mouth.
Dec 15, 2007. 10:07 PMKim-CheapKidzClothes says:
Is there another way to grow moss? I actually don't drink beer and the thought makes me gag. I have a very strange home and one side has a dog house looking space for the generator. The rest of that floor is the garage. I've painted the generator compartment and want moss to cover the concrete. I've never tried to grow it but was going to actually paint it when I had the time. Thanks
Mar 6, 2010. 9:21 AMyellowexample says:
 Well, according to sciphii's instructable (www.instructables.com/id/River-in-a-Jar/), buttermilk and sugar will raise the acidity to the point that will make moss grow.
Jan 31, 2010. 5:26 AMnutsandbolts_64 says:
 Are you trying to camouflage your generator compartment. Hey cool! Home grown camouflage!!
Jan 31, 2010. 5:21 AMnutsandbolts_64 says:
 I just read Berkin's comment. Then, I said to myself, "So you can actually *grow* explosives in your lawn". Kinda' funny if you think about it.
Jan 21, 2010. 7:31 AMMamohau says:
Moss painting & sculptures which should interest you!  do some searches on those key words...
http://www.apartmenttherapy.com/sf/how-to-paint-moss-designs-in-your-garden-077167
Dec 20, 2009. 4:51 PManimecello says:
these are cool
Nov 19, 2009. 6:59 PMuldron says:
it would be neat to see the result
Aug 25, 2009. 5:37 AMknex_mepalm says:
i am not blowing on somehting thata has moss in it, you know that if moss gets into your lungs you can get an infection from them growing and have a 95% chance of dying
Mar 3, 2009. 1:19 PMd2j5 says:
thats cool, i know that milk will work as a fertilizer aswell, im not shure how good it might be getting tossed at stuff but the milk does work.
Jun 19, 2009. 1:48 PMbobwantzanapple says:
buttermilk is better
Jun 22, 2009. 5:17 AMd2j5 says:
really? i never thought it would make a difference but i have used just normal milk and it works fine
Aug 11, 2009. 4:36 PMMark Drees says:
It's more acidic which helps the moss grow...
Jan 19, 2008. 9:50 PMMr. Deeds says:
Interesting. I don't suppose you could put large quantities of this in buckets and use it as a paint of sorts? I personally like the idea of moss painting.
Jul 13, 2009. 6:30 PMkikiclint says:
I would leave the paint out of the mix if using it as an actual paint.
Apr 24, 2009. 6:40 AMVulcanator says:
post pics of the moss after it has grown
Jun 24, 2008. 5:13 AMred devil 2 says:
it was fun making the moss bomb but you must use paint
Nov 20, 2008. 8:36 AMBerkin says:
You can make explosives out of dried moss powder called lycopodium or something of the sort.
Nov 21, 2008. 6:55 AMBerkin says:
Yeah, you could try the wiki for lycopodium.
http://en.wikipedia.org/wiki/Lycopodium
That will tell you a lot about lycopodium, its uses, and which species of moss to get it from. You can also buy it in some places (online).
Brainiac Science Abuse has a show called "Dr.Bunhead". In one episode on April Fools Day, Dr.Bun sprinkled lycopodium powder in his friend's light fixture. When he turned it on, the whole thing burst into flames and destroyed the bulb along with it.
(Note: If you find 2 of this comment in your inbox, it's because I had to fix a minor spelling error.)
Feb 23, 2009. 2:46 PMSebastopol Plantman says:
It's actually the spores of the club moss (Lycopodium), and collecting the spores will take a LONG time, unless you have a seriously large stand to collect from (or unless you can buy it). It's what they used for flash photography (remember the period shows where a person would be looking through the camera and holding a short pole with a platform on top of it...he'd trigger the camera, and the powder--on top of the platform--would flash: that's one of the powders they used for the flash.)
Jul 30, 2008. 11:44 AMUltraMagnus says:
pics showing it worked or it doesn't....
1-40 of 50next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
33
Author:splnlss(joncohrs)
I teach, work on art projects, and master music. For more info on me go to http://joncohrs.com or for more projects go to http://splnlss.com for audio go to http://spleenlessmastering.com thx!! Feel f...
more »
