Moxx's Handheld Grenade Launcher
1,336
33
Published
Introduction: Moxx's Handheld Grenade Launcher
About: none-ya business
i love this gun.  its a handheld grenade launcher, and its smaller than most pistols.  it fires a big grenade, basically just two connected blue connectors, but obviously doesnt fire as far as the best pistols.  when you fire it the grenade will sometimes split in half so its even cooler.  please SUBSCRIBE AND RATE.
Step 1: Pieces
1) make two
2) build
Step 2: Building It
1) connect
2) connect
3) add outside layers
4) with bands and ammo, unloaded
on pic 4, dont leave out the rods on and near the ramrod and the one on the trigger that i forgot on the last few pics, and replace the white one over the outside yellow piece with a blue.
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    33 Discussions
    eh i guess. personally, this is my favorite trigger ive even used. its small, reliable (if cut smoothly), and it puts the trigger ahead of where the ramrod is blocked, making it powerful and easy to build a small gun around.
    Ehh it could but it has a ram so it would interfere with the gun its self...but his other grenade launchers work well i used one on my m16 and it worked really well.
    oh, okay thanks for informing me, i just thought it would be good to use as a grenade launcher cause of the ammo and compactness
    Hmmm it would be for sure but not on a gun with a normal magazine placement..maybe a bull pup style gun?hmmm that gives me an idea to work on..
    i found a nice break action shotgun that i think it would go perfectly on. it is by owenmon, allyou have to do is put the grenade launcher on blue rods instead of white, and copy the last layer
    its really just one of those guns that you feel satisfied when you have, at least for me.
    wow what a surprise, a negative comment. from this point on its really not worth talking to you or even reading your comments as you clearly have nothing constructive or positive to say.
    It's not negative, it's just a correction. I think the idea used here is great, but I'm just saying it's not a grenade.
    ok, im sorry i overreacted, but your comments tend to be negative and a little annoying.
    My comments are in proportion to the quality of the knex projects being made at the time. Just keep that in mind. I respect the people who took up my torch (RMconstruction, knexfoof, etc). People like them used to be like your first comment above, but they learned. Same for me when I was a newbie almost 3 years ago. I received the same comments on my projects when I was new, from knexers who have been here far longer than I have. The reason I post negative comments is so knexers learn from criticism.
    so you're trying to say that pointing out that it isnt not technically a grenade even though a knex launcher that fires a large projectile is generally called a grenade launcher despite the fact that it doesn't explode is going to help me become a better k'nex designer? i respectfully disagree. you have the right to say whatever negetive comment you want to anyone or the site, but i would prefer that you leave me out of it unless its a simple tip or idea.
