Multi-bot Basis
Published
Introduction: Multi-bot Basis
About: Hey YOU! Yeah, I'm talking to you who is reading this. Send me ideas for instructables, like things that you are wondering how to make or build, or really anything electronically related, and I'll get back t...
In this Instructable we will show you how to build our multibot basis to build our other multibot based robots. It is very simle. It is great because you are not limited to our projects, but you can make your own. (Note the picture above is just an example of using the parts, not what will be accomplished in this project)
Submitted by Newton Labs for the Instructables Sponsorship Program
Step 1: Materials/Tools
Materials:
screw driver
plexiglass
2.5 cm X 20 cm of aluminum
Arduino
Tools
ruler
drill
grinder
band saw
Step 2: Cut the Metal
Cut the metal to (2.5 cm X 20 cm ) with the band saw. So that you get a medium sized piece to drill holes into.
Step 3: Drill Mounting Holes
Drill holes 0.3625 inches apart so that you get the correct size for a servo to be mounted on.
Step 4: Drill Holes Into the PlexiGlass
First mark with a pen or sharpie the location on the holes of the Arduino are to mount it. Then use the Drill press/drill to drill holes into the plexiglass where you indicated to mount the Arduino.
Step 5: Arduino to Plexiglass
Now you put screws in and screw it into the plexiglass.
Step 6: DONE!
Your basis is done and is now ready to be used for multiple projects that involve fun and games. It is very helpful , yet is very simple to craft. Thanks, Newton Labs team! (Credit to Starbot for use of their facilities)
    • Planter Challenge
      Planter Challenge
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    4 Comments
    Yes, we are mounting the Arduino to the plexi glass After we drilled the holes to mount it with. (In step 2 it is only the materials, dont worry too much about the pictures. Regards, Newton Labs Team
    But WHY? What is the point of the instructable ??
    Its to have the parts to build robots based off of this later. Example Waveinator. We have built multiple others its just we have alot on our hands at the moment to do.
