3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
musical beat thief
musical beat thief
No we're not stealing musical beats of any kind but we are going to make leds flash to music using a joule thief circuit with a slight modifacation
Step 1Finding parts
finding parts
you could buy parts or salvage them like I did , but anyways you need :
toroid bead
3.5mm audio jack
thin wire
led (any colour)
270 ohms resistor (red,violet,brown,gold)
s9014 transistor or equivalent
stripboard (optional)
( http://www.datasheetcatalog.org/datasheet/auk/STS9014.pdf ) datasheet for the transistor.
27 comments
Nov 22, 2009. 8:53 AMjacob5680 says:
 I think I blew up my transistor while soldering ( way to hot ) and the transistor is actually emitting sound... O_O I can hear the beats of my music from the transistor
Nov 22, 2009. 8:57 AMjacob5680 says:
Fixed the problem by reversing the resistor and ground. :P
Aug 2, 2009. 8:00 AMderbert says:
(removed by author or community request)
Aug 3, 2009. 1:25 AMderbert says:
i used a transistor that went red, violet, red, gold. does that matter?
Sep 10, 2009. 3:16 PMPyroMonger says:
Its not a transistor its a resistor you are talking about and perhaps it should of been mentioned that you need an NPN transistor not a PNP one.
Sep 15, 2009. 12:29 PMderbert says:
yh yh cheers my bad. my transistor is the kind detailed. just wondered if the resistance was wrong and needed changing.
Sep 10, 2009. 3:18 PMPyroMonger says:
nice ible anyway...I've got a strip of 3 blue LEDs wired to my laptop subwoofer for some sweet ground effects everytime the bass kicks...I love it....I did this for my friend's car too...underdash lights that go with the beat. I LOVE LEDs _
Oct 18, 2009. 6:06 PMtinkerman92 says:
hopefully not wired directly in after the amp because if it is it can make for bad sound quality or even damage your system
Oct 19, 2009. 4:00 AMPyroMonger says:
u cant wire it b4 the amp or it wont light up...the amp gives it the extra power it needs to be lit because the louder i play musisc the brighter the LEDs. No problems so far and have this set up for almost a year now
Aug 4, 2009. 11:37 PMderbert says:
what input would you suggest?
Jun 28, 2009. 6:04 AMzoltzerino says:
would a bc108 c work??? ZZZZ
Jul 4, 2009. 10:16 AMzoltzerino says:
I have just made the 'standard' JT I have no resistor before the base and I am using a bc108c. It only works with AAAs not AAs it just flickers with AAs. Current overpowering tran??? ZZZZ
Jul 20, 2009. 3:20 PMzoltzerino says:
I made a MBT and it works, I even split the audio so i can listen and flash! Although it only flashes at a painfully high volume, is it my bc108 (do I need a low voltage transistor) or have I got the wrong amount of turns on my toroid??
Jul 31, 2009. 5:45 AMzoltzerino says:
ok thanks
Jul 21, 2009. 3:19 PMBiotele says:
can you post a video of the LED flashing to the music?
Jun 27, 2009. 5:18 AMfrollard says:
The solder DID ruin the photo - the camera focused on the solder instead of the project! ....USE MACRO MODE FOR CLOSEUP PHOTOS!!! :D If you don't have macro mode, then since its gonna get sized down by instructables, then take a picture, in focus, from farther away - then crop it. Pictures aside - neat project! Extremely low lowpass filter :D
Jul 3, 2009. 10:48 AMKokkan says:
We have a photographer in here RESPECT
Jul 4, 2009. 10:17 AMzoltzerino says:
Restecpt. Ali G... IN DA HOWS!
Jun 26, 2009. 8:38 PMironsmiter says:
hmm. I wonder if anyone knows(or knows how to calculate) the resistor value to put one of these IN-LINE with a headphone speaker. I'm thinking a nice blue led synced with the music on my headphones. I get music, and the people around me get a light show!
Jun 26, 2009. 5:20 PMEmsaid says:
the solder didnt ruin anything... ...the picture already was ruined! (Just kidding!!) Very cool!
Jun 26, 2009. 12:32 AMhominid says:
Very good and clear. I like the new use for the JT. Thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:frag_bomb
