Musical Beat Thief
Published
Introduction: Musical Beat Thief
No we're not stealing musical beats of any kind but we are going to make leds flash to music using a joule thief circuit with a slight modifacation
Step 1: Finding Parts
you could buy parts or salvage them like I did , but anyways you need :
toroid bead
3.5mm audio jack
thin wire
led (any colour)
270 ohms resistor (red,violet,brown,gold)
s9014 transistor or equivalent
stripboard (optional)
( http://www.datasheetcatalog.org/datasheet/auk/STS9014.pdf ) datasheet for the transistor.
Step 2: Construction
First off I would start with the toroid you need really thin wire with quite thin insulation, you want about 9-11 wraps around the toroid bead. After that you should solder two different wires from opposing ends together, so now you should have 3 wires coming out of the bead the two you just soldered are now the + in wires,now take one of the remaining wires and solder the resistor to it then solder the resistor to the middle pin of the transistor , take the last wire from the toroid and solder it to the collector of the transistor.
Solder the + leg of the led to the collector on the transistor and the - leg to the emitter.
Also add a length of wire to the - leg of the led for the ground wire.
Then solder the ground wire to the 3.5mm jack and the positive to the left or right channel.
Step 3: Finished
Now plug it into a music sorce and hope for the best.
I've found this wont work with some mp3 players with low volume but it works on laptops and tv's
they also make great badges and if you add another 3.5mm jack you can listen and watch it flash although i havent tried it and it might distort you music a bit.
If you want it to flash more lower the resistor value, I have mine so it flashes to singing but if you put in a higher ohm resistor you could make it only flash to bass.
Another idea is to make two and have one for music left ouputt,and one for music right output i imagen that could be quite fun to watch
Doesnt work ? :
try turning up the volume on the music sorce
check connections on all soldered parts
make sure you havent put the transistor or the led the wrong way around
    • Woodworking Contest
      Woodworking Contest
    • Microcontroller Contest
    • Casting Contest
      Casting Contest
    21 Comments
     I think I blew up my transistor while soldering ( way to hot ) and the transistor is actually emitting sound... O_O I can hear the beats of my music from the transistor
    you should deffiently put that on youtube =D
    Fixed the problem by reversing the resistor and ground. :P
    i used a transistor that went red, violet, red, gold. does that matter?
    yes it does , at that resistance i dont think it will work but depends on your input i suppose
    nice ible anyway...I've got a strip of 3 blue LEDs wired to my laptop subwoofer for some sweet ground effects everytime the bass kicks...I love it....I did this for my friend's car too...underdash lights that go with the beat. I LOVE LEDs _
    hopefully not wired directly in after the amp because if it is it can make for bad sound quality or even damage your system
    u cant wire it b4 the amp or it wont light up...the amp gives it the extra power it needs to be lit because the louder i play musisc the brighter the LEDs. No problems so far and have this set up for almost a year now
    what input would you suggest?
    at that resistance probably not sound, lower your resistor value and try with whatever musical device you can plug it into
    Its not a transistor its a resistor you are talking about and perhaps it should of been mentioned that you need an NPN transistor not a PNP one.
    yh yh cheers my bad. my transistor is the kind detailed. just wondered if the resistance was wrong and needed changing.
    Well done on making it, i think a lower voltage transistor would be best you want a lower emitter - base voltage to get it to flash at lower volume.
    can you post a video of the LED flashing to the music?
    try it with a resistor you need it to determine the current output of the transistor ....... i think
    The solder DID ruin the photo - the camera focused on the solder instead of the project! ....USE MACRO MODE FOR CLOSEUP PHOTOS!!! :D If you don't have macro mode, then since its gonna get sized down by instructables, then take a picture, in focus, from farther away - then crop it. Pictures aside - neat project! Extremely low lowpass filter :D
    We have a photographer in here RESPECT
    see no reason why not, try it
    hmm. I wonder if anyone knows(or knows how to calculate) the resistor value to put one of these IN-LINE with a headphone speaker. I'm thinking a nice blue led synced with the music on my headphones. I get music, and the people around me get a light show!
    the solder didnt ruin anything... ...the picture already was ruined! (Just kidding!!) Very cool!
