soundie: a musical touch-sensitive light-up hoodie
Step 8Sew on your speaker
sew on your speaker
Sew on the speaker.
Using the same techniques as with the LEDs and other components, sew your speaker onto the garment. With the speaker I used, the + and - petals don't matter, but if you're using a different speaker, be sure to pay attention to which is which. The + petal should be connected to one of the numerical petals of the LilyPad main board (I used petal 9), and the - petal should be connected to the - petal of the LilyPad main board.
Test the speaker.
Here's the code I used to test the speaker. If it works, the speaker should hum a fairly constant C note.
int speakerPin = 9; // speaker connected to digital pin 9
void setup() // run once, when the sketch starts
pinMode(speakerPin, OUTPUT); // sets the speakerPin to be an output
void loop()
beep(speakerPin,2093,1000); //C: play the note C 500ms
void beep (unsigned char speakerPin, int frequencyInHertz, long timeInMilliseconds) // the sound producing function
int x;
long delayAmount = (long)(1000000/frequencyInHertz);
long loopTime = (long)((timeInMilliseconds*1000)/(delayAmount*2));
for (x=0;x<loopTime;x++)
digitalWrite(speakerPin,HIGH);
delayMicroseconds(delayAmount);
digitalWrite(speakerPin,LOW);
If the speaker does not work, use the multimeter to test for shorts with the instructions from the previous step.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:kanjun
