Step 2More power!
This step will show your how to super power the Nerf gun.
First. open up the case, by unscrewing with the screw driver.
Second. detach the top piston spring, then take out the second 1"in spring and place inside the larger spring, make sure it only sticks about one fourth the way, when lined up with other spring, if not use the wire cutters to cut the right about off.
Third. Take the wrench, clamp the spring and push the way that the spring goes until it gits large enough to fit the spring couple.
Fourth. shove the spring back in place and make sure it fits and will lock in place when cocked.
comment
Add Comment
Add Comment
