3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
never scratching cd/dvd protection
If you keep old files and backups on cdr or other optical media you have probably had some disks go bad over the years even though they are stored properly. The normal plastic "jewel" cases, folded paper sheets, and commercially available storage methods all have the potential to damage your cds and cause your valuable data to be lost.
This storage method keeps your cds from taking any abrasive damage, and also prevents damages caused by the aging of the plastics and resins the disks are made of. It's simple, cheap, and damn near fool proof.
Step 1Put your cds into fold top sandwich bags
put your cds into fold top sandwich bags
That's all, just slide them in, fold it over, and the plastic bag will trap precious organic volatiles in while keeping harmful grit out.
cost ~$0.005 per bag
41 comments
1-40 of 41next »
Feb 19, 2011. 5:57 PMnil tacs says:
cutie kittes
Aug 29, 2009. 11:19 PMjtmax24 says:
Very nice instructable.... I haven't thought of sandwish baggies... normally I just buy a spindle of cd-r/dvd-r's and backup to those and then put the backup copies back on the spindle... I just checked 200 cd-r I did back in 2003 and 2005 all but one didn't work... not bad odds...
Aug 8, 2008. 2:02 AMxacked says:
Epic. fail. The steps, not the idea itself, which I have to say is an interesting notion worthy of trying out.
Nov 11, 2007. 8:17 AMerqua says:
It looks to me like the plastic may stick to the CD after a few months/years, depending on the kind of ink used the print the CD (the same way vinyl reacts with and sticks to photostat toner). I've a printer driver CD that came in a paper envelope with a clear see-through front "window". After about 3 years in storage, the plastic "window" reacted with the ink and sticks to the CD. When I tried to tear it off, strips of the metal layer came off, rendering the entire CD useless. If the envelope had been entirely paper, the problem wouldn't have occurred.
Jul 4, 2008. 5:36 PMBartboy says:
Use Mylar.
Mar 10, 2008. 5:47 AMsideways says:
The bags used are food-grade; usually more non-reactive than other plastics. Plastics labeled for food storage need to be more inert than others because humans eat the food stored in them. They might also have less residue of solvent-type chemicals from the manufacturing process because of this.
Dec 6, 2007. 12:24 PMBr0 says:
KITTENS AAAAAAAAAAAAAAAAAAAAAAAAAAaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
Dec 10, 2007. 2:03 PMojochris says:
lol
Feb 10, 2007. 3:18 PMlemonie says:
You do need to specify what platsic your bags are made of. Also, how long have you stored CDs to verify an advantage over jewel-cases? I suspect that this is unproven. Also, scratching occurs through handling, not storage. if you get these out of the archive they're just as vulnerable as disks archived in jewel-cases.
Feb 18, 2007. 3:05 PMlemonie says:
Probably polyethlene? My worst problems with CD storage have been corrosion of the metal layer, I do not know what caused this (in excess of 2 years though) L
Oct 26, 2007. 3:38 AMstib says:
Sunlight kills rewritable optical media very quickly. UV light is used in the recording process, so leaving CD-Rs etc in the sun is like leaving a cassette tape on a big magnet.
Jul 10, 2007. 1:08 PMPSPerson says:
yeah that's why i never burn CDs anymore i use USB thumb drives and external hard drives (i have a 1 tb drive)
Mar 9, 2007. 8:18 PMPSPerson says:
FORGET CDS try a box of USB flash drives!!!!
Jun 14, 2007. 12:16 PMCrash2108 says:
Those don't last forever either.
Jul 10, 2007. 1:05 PMPSPerson says:
The only time i've ever had a USB flash drive break on me is when i loose them
Jul 10, 2007. 1:09 PMPSPerson says:
and i use an external hard drive
Jul 11, 2007. 10:08 PMPSPerson says:
huh? whatever i think hard drives are the cheapest and most space efficient storage for me. i HATE CDs, the only time i use them is for system installs and the like. i have several 100 gb+ hard drives not including my 1 TB external drive that i keep all of my media on.
Jul 11, 2007. 10:09 PMPSPerson says:
and it is in a VERY durable casing.
Oct 26, 2007. 3:34 AMstib says:
Ar you saying that you're relying on *hard drives* for archiving?! Why not just write all your data onto soap bubbles and store them in a box of drawing pins? Hard drives are not archival, they fail with alarming regularity. You've obviously missed the point of this instructable which is how to keep optical disks with archived material safe.
Either you don't have anything important on your hard drives, or you're headed for a disaster when (not if) your hard drive fails.
Oct 25, 2007. 11:10 PMcertron says:
I actually used this method a few years back when my local Linux User Group was distributing free copies of Knoppix. I bought the mega-pack of CDs and the bags at a warehouse-type store, so they were both cheap and convenient. The cheapness was very much appreciated!
Sep 22, 2007. 7:51 PMbedbugg2 says:
you could even get one of those vacum sealer just to make sure
Aug 28, 2007. 11:58 PMOra says:
So much unnecessary plastic makes me cry inside...
Mar 13, 2007. 10:26 AMbobsteads says:
I use d_skins have a look at www.dskin.com this is a protective skin that stays on the disk even in the DVD player of play station etc, no nead for any other protection
Feb 14, 2007. 1:58 PMdikenkaktus says:
well. but it can't be solve the problem
Feb 11, 2007. 6:01 PMcpf says:
From that picture, it looks like the CDs could slide back and forth on top of eachother and sctratch themselves, the solution is to bolt them securely through the center holes to a big metal plate embedded in a tonne of concrete :-) Good idea, though I am sticking with hard drives for now If I ever have to back up a tonne of stuff to disks, I would consider this (the only problem being writable CD/DVDs will naturally oxidize or something that makes them unreadable...)
Feb 9, 2007. 3:52 PMTNT64 says:
Feb 7, 2007. 11:06 PMShark500 says:
And pray, what is the most popular cheese around these parts?
Feb 9, 2007. 10:18 PMshadymilkman says:
well, from my experience working at a Subway, here it is the Pepper Jack, followed closely by American (often pronounced "Mercan" or "Ahmetican")
Feb 8, 2007. 9:04 PMToddR says:
Feb 8, 2007. 11:22 AMcrapflinger says:
hehe...that fat headed fluffy cat in the back looks like he's about to crap himself...
Feb 7, 2007. 10:45 PMbillbob says:
this instructablesays cds "breath"..would this prevent them from breathing?
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:pir8p3t3
