Remove these ads by
Signing UpStep 1Building the unit
ok first what youll need...
electrical tape
glove (any kind of glove will explain later
wire (lots)
some form of box (altoids can woks best)
switch (small)
disposable camera
battery(i found that the cam flashes oldy work with one aa battery)
soddering gun
sodder
drill or scruedriver
carefullness this shxt hurts lol
ok first open the cam take out the batt and discharge the compasator (make flash go...flash.)
now the difficult part..
carefully take the bulb out compleatly cut it away if you have to just get the wires that the bulbs sodderd to showing.
ok the part where the wires touch to activate the flash sodder to gether or twist to gether. now where the bulb was sodder 2 seperate wires to each lead dont woory about the ground...you wanna make the thing shock lol.noy you should have the 2 small wire things twisted or sodderd together and you now made the wires the bulb were connected to long as hell id say about 3 foot should be good so now have 2 3 ft. wire's hangin leave them alone and now where the charge thing is (the button to press to charge it) bridgr sodder the 2 things together to make it one never ending pressed button lol.or if you wanna get fancy sodder a switch insted of a bridge sodder so you can turn it on and off as you please (cleaver aint i???) lol. any way...now oce thats all done wrap the whole unit in electrical tape but make it so you can still come back and add the battery later... and then grab your case and make a 2 small holes one for the wire that goes to the glove and one for the switch...but make shure you can still close your box lol i made that mistake b4 lol it kinda sucked lol. now the units done now go to stpe 2 to make the glove
i have zapped myself in the arm and ribs
it is rated at 950,000 volts
it is pretty strong
or if you get the right circuit board use one of the charger circuits (its the same as the shocker)www.instructables.com/id/Coilgun-Handgun/
i hope this helps.
