Sparkleball (no-melt) for the Holidays!
 by sparkleball_lady
Featured
A sparkleball is a magical ornament handmade from plastic cups and mini-lights; usually displayed at Christmas or holiday time.
You'll need 50 soft 9 oz. tumbler-style plastic cups, a hole-puncher, a drill with a 1/2" bit, a string of mini-lights (100-150), and 200 small zip-ties. (recycled clean cups will work perfectly as will an old string of mini-lights.)
Step 1: Drill the Cup Bottoms
Drill the cup bottoms of all 50 plastic cups. You can stack and drill 2-3 at a time. The holes should be about 1/4 to 1/2" wide, or large enough to insert one or two mini lights.
Step 2: Punch Holes
With a hand-held hole-puncher (the kind for punching holes in paper), punch 4 holes evenly spaced around the top of all 50 cups. Place the holes just under the raised lip. Each hole should have a hole directly opposite, but just eyeball the placement.
Step 3: Layer One
Arrange 12 cups in a circle. Attach each cup to the cups adjoining, using a zip-tie through the holes. Do not tighten the zip-ties until all the cups are connected. Then cinch each zip-tie tightly, one by one, making sure the ring of cups stays flat. Trim zip-ties.
Step 4: Layer Two
There are 9 cups in Layer Two. Place one cup on top of Layer One. With a zip-tie, connect this cup to the cup it sits on top of. Do not tighten the zip-tie all the way. Now add a second cup. Attach it with a zip-tie to the cup it sits on top of. When all 9 cups are situated on top of Layer One, forming Layer Two-- then attach each cup to the cups on either side. Every cup in Layer Two will be attached at three points. When all the zip-ties are in place, go around the ring, tightening and trimming all zip-ties.
Step 5: Layer Three
There are 4 cups in Layer Three. Fit the 4 cups into the space left at the top of the sparkleball-half. Once they fit neatly, then start attaching the 4 cups to each other and to the cups in Layer Two. The last 4 cups will be attached at 4 points. You may need to punch new holes, if the holes don't align. (AND you may end up leaving some holes unziptied.) Tighten zip-ties and trim. Half the ball is done! Now you start threading the mini-lights.
Step 6: Inserting Lights
IMPORTANT! TEST LIGHTS BEFORE YOU INSERT THEM.
To insert lights: start at the prong end of the cord. Insert the two lights closest to the prong into a cup at the outside rim. (The plug will then hang out when you put the two halves together.)
Put 1 or 2 lights in each cup. Work your way around the ball half, zigzaging from outer cups to inner cups and back. You want to end up on the outer rim, at the cup next to one you started with.
Work slowly. It's important NOT to skip a cup or miss a light. If you crack a cup, that's ok.
Step 7: Build Second Half
Set aside the completed half. Build the second half just like you did the first. (Steps 3 - 5)
Step 8: Finishing the Lights
On the second half, insert lights starting from the opposite end of the cord (the plug end.) Start with any cup but make sure you finish at the outer rim. (But if you plan to hang more than ball at once, make sure the plug end hangs out between the cups, as well.)
The last lights will be the hardest to insert as you juggle the two halves. Some people use two strands of mini-lights, connecting them once the two halves are threaded with lights.
Step 9: Join the Halves
Press the two halves together, making them fit snugly. Line up holes and attach loosely with zip-ties, all the way around. Then pull zip-ties tight and trim.
Step 10: Make a Hanger
Make a hanger for your sparkleball. I use a bit of chain and two "s" hooks. Choose the top of your sparkleball. (Will you want the electrical cord hanging out on top or at the bottom?) Punch holes between two cups. Insert an "s" hook into the hole and close. Add chain and second "s" hook.
You can also use zip-tie loops, clear fishing line, wire coat hangers, or ribbon to hang sparkleballs.
Step 11: OPTIONAL: Beads? Glitter?
My friend Erika likes to string plastic beads on the zip-ties, as she threads them between cups. Her sparkleballs look as pretty unlit, as lit. You can also dip cup rims in glue, then glitter, or use dollops of glitter-glue between the cups.
Step 12: OPTIONAL: Chasing Lights
Multi-function, "chasing" lights turn sparkleballs into mini-ufo's. The blinking, pulsating, rhythm-changing light sequences have to be seen to be believed. If you do use chasing lights, you'll need to insert 2 or 3 lights into each cup bottom. Experiment with drill and hole sizes and lights BEFORE you begin building your sparkleball.
Step 13: Plug in and Enjoy!
To see more free sparkleball expertise and photos of sparkleballs from around the world, check out sparkleball.com.
1-40 of 84Next »
monkeymays says: Apr 27, 2013. 3:40 PM
Great project for Christmas, and ever so pretty! My mom made me one in the late 80's and I had that thing for years. She used the multi-funtion light set but after several years use eventually only one color of lights were left working.
She used hot glue to secure hers, but I sure like the one pictured that had beads strung in with the zip ties.
Thanks for the great tut!
FrozenStar says: Dec 10, 2010. 9:03 PM
Pretty cool concept.
It would be awesome if you hooked some of these up into a sequencer so they could flash in a pattern.
sparkleball_lady (author) in reply to FrozenStarDec 11, 2010. 6:01 PM
http://www.youtube.com/watch?v=V-Ku3tmXg-4&feature=related
GroggDog says: Dec 11, 2010. 2:58 AM
I don't recomment this for people where it's cold in the winter lol. Tried this last year and after the christmas when I were going to take in back in it collapsed and all the cups cracked and all. If you wan't to do this where's cold then wait untill the summer or something
sparkleball_lady (author) in reply to GroggDogDec 11, 2010. 5:58 PM
Interesting. I know there are people who use them where it snows alot and in places like MN. Maybe it's the kind of cups or the method of putting it together you used? I've heard HotGlue won't hold in cold weather. But this is the first word I've heard of the cups shattering. :-(
Treasure Tabby says: Dec 10, 2010. 10:01 PM
Sparktacular! Love the idea, :)
Dr.Bill says: Dec 10, 2010. 7:29 PM
Well its December 10 and I am goimg to RAID the christmas light stores in a few weeks for the cheap lights. I like to use LED kine lights for long lasting display.
AntzyP says: Nov 29, 2010. 11:54 AM
The SparkleBall me and my sis made for an Indian festival of lights called Diwali...
sparkleball_lady (author) in reply to AntzyPNov 30, 2010. 7:14 AM
Dear AntzyP,
May I post your photos on www.sparkleball.com ? They are wonderful and would be the first made for Diwali! Will you email me at sparkleballlady@yahoo.com or here and let me know. I didn't want to download without your permission. If yes, tell me your first name and where you live so I can put you on the sparkleball map.
Thanks again!
Alex
AntzyP in reply to sparkleball_ladyDec 2, 2010. 2:11 AM
I wouldn't mind at all, you can go ahead and you can download it. It will be awsome! :)
I'll mail them to you as well.
Thanks for the great instructable. Had a lot of fun making it and got a lot of compliments too...
Antzy
New Delhi, India
sparkleball_lady (author) in reply to AntzyPDec 2, 2010. 7:52 AM
NEW DELHI, INDIA! Antzy, that is so cool. I can't wait to put you on the sparkleball map. You will be the first marker in Asia. If I have any trouble downloading, I'll contact you again. Best wishes to you and your sister!
Alex
Sonoma CA
AntzyP in reply to sparkleball_ladyDec 2, 2010. 8:59 AM
Thats great! I've mailed you the images in case you have any trouble...
-Antzy
Kryptonite says: Nov 27, 2008. 1:32 PM
I believe that you could make one of these out of plastic clear shot glasses, so you get a really small one. Could you? regards, Kryptonite
sparkleball_lady (author) in reply to KryptoniteNov 28, 2008. 9:31 AM
Dear K, I've made a mini-ball out of condiment cups (like you get ketchup in at hamburger places.) But a man in Australia built a really beautiful smaller ball made out of red shot glasses. Not sure how he did it but you can see photos of his mini and mine at [http://http:..www.sparkleball.com/intro.htm sparkleball.com]. Alex
twighahn in reply to sparkleball_ladyNov 18, 2010. 9:48 AM
one coudl use thimbles too
koda1 in reply to sparkleball_ladyNov 30, 2008. 3:58 AM
Where do you get the ties from? Can you buy them separately? Thank you.
sparkleball_lady (author) in reply to koda1Nov 30, 2008. 7:09 AM
Koda, You can buy them at any hardware store or Home Depot. My husband introduced me to them, and they come in very handy for a variety of uses. I can't live without them now.
Kryptonite in reply to sparkleball_ladyNov 28, 2008. 11:04 PM
Hey Yeah, that dude in Australia did what I'm thinking about, which is good cause I live in aus too so I can probably get all the stuff. Thanks for the reply, Kryptonite
sparkleball_lady (author) in reply to KryptoniteNov 29, 2008. 8:13 AM
Well, Aussie Kryptonite, if you do make a shot-glass sparkleball, I'd love to see how you do it. So I hope you post it here and let me know. The one Rob made is one of the prettiest ever. I know he used like 100 cups, but the trick is always making the ball come out round and it's harder when the cups have straight sides. . .
Kryptonite in reply to sparkleball_ladyNov 29, 2008. 11:33 PM
Rightio then! I may or may not make this, I'm a bit busy with school at the moment. Although, for the good instructable, nice attitude and quick replies I'll give you a 4.5/5. Thanks for posting! Kryptonite
jmahurin40 says: Dec 1, 2009. 8:54 AM
I've been making these for years.
I have gave gobs away for gifts and sold alot of them.
I usally use the 16 function lights from walmarts.
I've sprayed some with snow that comes in the can and used the plain colorful twinkling lights and they were pretty hung outside.
I use a sodiering iron to make my holes in the my solo cups for the lights and and then use a small high temp. glue gun to melt the cups together.
No hot glue used just the hot glue gun tip.
I had 2 use the sodiering gun to melt off the built-in  stand on the glue gun to fit it into my cups.
They are nice to use on floats in parades if people have a way 2 hook up to electric.
I've made some with plastic medicine cups.They were kinda hard 2 make exactly round and were very tedious but were cute.Some came out in an egg shape but were nice for easter.lol
twighahn in reply to jmahurin40Nov 18, 2010. 9:45 AM
one could use staples to hold them together too
sparkleball_lady (author) in reply to jmahurin40Dec 1, 2009. 9:37 AM
I'd LOVE love love to see any photos you have.  What great ideas!  If you get in the sharing mood,  I'd love to show your sparkleballs off on www.sparkleball.com   It's a totally free, just for fun, sharing website.  If you're interested lemme know.  Or you can go to the "contact" page.  I'd especially love to see the snowflake ones.  Never seen that before.  Happy Holidays!  (OR just post your photos here?  Easy to do with the "Add Images" button.)
twighahn says: Nov 18, 2010. 9:43 AM
this would go well with the tree made of 7-up bottles
grooooovy says: Aug 24, 2010. 9:52 AM
This is cool- I've never heard of these before!
nomij says: Nov 27, 2008. 10:56 AM
Though I've seen these before, this is the best "How To" I've seen so far! Excellent instrucable! I followed the link also, and they look beautiful outside! I just wonder if they are safe to hang outdoors? I guess they make outdoor friendly fairy lights! Thanks for sharing!
vwluvrs in reply to nomijDec 1, 2009. 2:30 PM
Absolutely safe to use outdoors! We have some that are a few years old, and have never had an issue with the electricity. Just make  sure you use the light strings rated for out door use (it'll tell you on the box).
If they get wet, damaged, snowed or rained on, they are still as safe as any other outside light string.
Hint: At the end of the season (or when you do bring it inside) spray it liberally with some foaming glass cleaner, let it sit for a while, then spray it off gently with your water hose. After it dries, you can store it and it will be clean and ready for its next debut.
mchumchal says: Nov 25, 2009. 10:06 PM
Very helpfull!  I made one with my soldering iron and it ended up taking about 92 cups and hours to make.  This method is flawless!  Thanks!
sparkleball_lady (author) in reply to mchumchalNov 26, 2009. 8:11 AM
did it turn out similar to the Godzilla sparkleball?  love to see a photo!
knowonesreal says: Nov 23, 2008. 1:59 PM
thats off the hook 4 real....... ima do 1 ...but im goin to sand the plastic cups so they look frosted...the the light will transfer different threw them
vwluvrs in reply to knowonesrealNov 19, 2009. 10:53 AM
Instead of sanding them, simply do a light spray with white paint...
Zem in reply to vwluvrsNov 19, 2009. 9:20 PM
Or you could spray with glass frosting spray? Don't know how well it would stick to the cups though
sparkleball_lady (author) in reply to ZemNov 20, 2009. 9:28 AM
Check this out.  A sparkleballer used spray glitter in his cups.  Really great!
www.sparkleball.com/glitter.htm
Zem in reply to sparkleball_ladyNov 20, 2009. 1:35 PM
Now THATS a sparkly sparkleball!
lilpepsikraker says: Aug 17, 2009. 4:22 PM
GEEK. IS. GOING. TO. EXPLODE! WOW that's awesome!
Audey says: Dec 8, 2008. 6:00 AM
<a href="http://www.instructables.com/id/Christmas-Disco-Ball/">http://www.instructables.com/id/Christmas-Disco-Ball/</a> has been arouns for a year longer... who's idea was this?<br/>
sparkleball_lady (author) in reply to AudeyDec 8, 2008. 6:59 AM
Nobody knows whose idea this was. It's an American folk craft I've never been able to trace the origin of. That's why I built a website celebrating sparkleballs. I'm still waiting for someone to tell me who invented the first one. . .
Audey in reply to sparkleball_ladyDec 8, 2008. 7:48 AM
which came first; the sparkleball or the cup? I guess it's possible this is an ancient way of making balls, and they got they idea of cups out of it. i'm tired.
sparkleball_lady (author) in reply to AudeyDec 8, 2008. 8:07 AM
I always thought maybe it was somebody sitting around drinking who thought it up-- I mean really! Plastic cups and Christmas lights? How bizarre a combo is that? I really would love to know. I bought my first one by the side of a Texas highway over 25 years ago.
karen608 in reply to sparkleball_ladyMar 11, 2009. 10:11 PM
ooh i should have known you'd be on instructables.... every great homemade item is here! Now i am dying to make one by next late Novemberrrrr. : )
1-40 of 84Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
