Step 6Inserting Lights
To insert lights: start at the prong end of the cord. Insert the two lights closest to the prong into a cup at the outside rim. (The plug will then hang out when you put the two halves together.)
Put 1 or 2 lights in each cup. Work your way around the ball half, zigzaging from outer cups to inner cups and back. You want to end up on the outer rim, at the cup next to one you started with.
Work slowly. It's important NOT to skip a cup or miss a light. If you crack a cup, that's ok.
Add Comment
