very simple.... no tools needed repair! no wheel removal! works on all tube sizes! it will hold air for a good while. definitely enough to get you to a shop or home. i learned this trick from a elderly fella....... pay attention to the old and wise!
Simple good idea. But to be a stirrer, does the credit card not become a "tool" by it's use? Sorry, just had to ask. I do see it as a quick fix to at least get you home. I like it.
I suppose, but so are my hands. the card is unnecessary. I started using it as a visual aid to show the tire half mounted. then figured it was such a common item that i could give it purpose; perhaps help the softer handed cyclist :)
A quick, very creative, "no-tools" way of dealing with flat bike tires. HOWEVER, you left out one important step. Begin with marking the location of the tube stem on the tire (in case the tire moves on the rim in the process of removing the tube).Then after locating the hole in the tube, find that same location on the tire and carefully reach into the inside of the tire with your finger to find the nail, thorn or glass that caused the flat in the first place. Remove that offending sharp object and continue with your tire repair as described. If you do not remove the cause of the flat, it may re-occur with your temporary patch OR when you put in a new tube. I learned this the hard way.....
Neat idea! Couldn't you just tie a knot in it without cutting it in half? That way you get it home or to the shop then you can patch it proper without having to buy a new tube. Just wondering.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
thanks for the comment! should i edit my tutorial? i'm new & unsure......
