A Newbie's Guide to Setup ESP8266 With Arduino Mega 2560 or Uno
477,986
283
33
Published
Introduction: A Newbie's Guide to Setup ESP8266 With Arduino Mega 2560 or Uno
About: Your focus determines your reality
For any open source products to be successful or adoption en masse by the "makers"/ "DIY-ers" / "dev" / "etc"; an up-to-date and accurate documentation or quick start guide has to be provided. User's posts in discussion forums are good, but the bits and bites of (usable) information are hidden in the troves, hiding deep inside irrelevant comments/posts. This might discourage the faint-hearted from "looking harder" at the problem. After scouring the Internet to find some leads on why the setup via "official" guide has failed, the good reads discovered are placed in the references section. From a seeming "easy" writeup on the SEEEDstudio official guide, it took many hours trying to troubleshoot the setup to make it to work..
To save you from the frustrating moments, let's cut the chase and go straight to what works. If you are interested on what doesn't work, read between the lines or skip the steps below till the "what works /does not work" section.
There are a few parameters that will make or break this setup. Due to unforeseen err in documentations/writeups, the following parameters that worked were result of bruteforced effort.
check out an 2016 update on using ESP8266 the ESP-01 variant without Arduino Mega or Uno by using a DIY maker IoT board URL here: https://www.instructables.com/id/Makers-IoT-Kit-for-ESP8266-ESP-01/
data is on blog http://shin-ajaran.blogspot.sg/2015/11/makers-iot-kit-for-esp8266-esp-01.html
check out an 2016 update on the latest offering of the big brother of ESP8266, the ESP32 to be released in 2016 URL: https://www.instructables.com/id/Beginners-ESP32-Guide-to-Assembly-Testing/
The parameters relevant to this setup are
ESP8266 version
Choice of "matching" baudrate (e.g 9600, 57600, 115200) for 2 sets of serial comms: ESP8266<->Arduino, and Arduino<->USB serial monitor (hardware serial or software serial)
Choice of 5v and 3.3v bridging circuitry between Arduino and ESP8266
Choice of Arduino Mega or Uno, that affect the availability of serial comms
Choice of terminal software
Choice of code for testing
Yours truly recommends Arduino Mega with ESP8266, using either logic level shifter or voltage divider, and Serial Monitor.
Assuming you only have an ESP8266 and an Arduino, trying to make ends meet without another FTDI breakout board for the softserial, you are not out of luck. Check out the 2nd last page for the source code that uses RGB LED as indicator instead of softserial.
for the context/background info of this setup: http://shin-ajaran.blogspot.sg/2014/12/noobs-guide-to-esp8266-with-arduino.html
Step 1: Hardware Needed
Hardware needed
0. ESP8266 aka ESP-01. This one is manufactured by SEEEDstudio. It runs off 3.3v only; can be powered off arduino's 3.3v pin or a separate supply with 3.3v and 500mA. Do not plug a 5V source to it.
1. break out board for ESP8266. This is made of a 4x4 veroboard, PCB headers, and jumper header. Be sure to score a line to separate the copper strips from shorting the adjacent pins.
2. Serial comm options on Arduino(s)
ESP8266 and Arduino needs 2 serial comms; either 1 hardware 1 software or 2 hardware serial.
Arduino Mega is preferred because of the 4x hardware serial. The nett effect is serial0 can be used for monitoring on PC USB, serial1 or2 or 3 can be used for comms between arduino and ESP8266 to issue the AT commands
or
Arduino Uno and a separate FTDI serial to USB breakout board. In the references section, some writeups suggested the limited baudrate on softserial affects the readout of ESP8266 on serial monitor. (more about this later)
3. logic level shifter
Arduino speaks 5v and ESP8266 speaks 3.3v.
option A: plug directly the TX-RX pairs between arduino and ESP8266. If used, there is a risk of damaging both of them. You might get lucky for getting away with this? How many times you can get lucky?
option B: use a voltage divider circuit to divide 5v source from Arduino to 3.3v source for ESP8266. Acceptable methods, definitely much better that plugging in directly.
URL for voltage divider calculation: https://www.abelectronics.co.uk/tools/resistor-vo... ; Vin is 5v, Vout is 3.3v (ish), enter either R1 or R2 with a resistor value available at your disposal.
The following diagram describes the setup with a 330ohm and 180 ohm resistors (the only 2 resistors available on hand at the time of making) voltage divider circuit
option C: logic level shifter, e.g those sold by sparkfun. This method is highly recommended
4. wiring scheme
Rule of thumb: always check pin out diagram before wiring, ensure common ground, vcc and gnd are connected according to voltage specs. ESP8266 CH_PD aka chip power down and RESET are connected to 3.3V for logic high; TX & RX pair for comms: ESP TX-> Arduino RX; ESP RX-> Arduino TX
Assuming using Arduino Mega Serial2 (pin #16 and #17), ESP8266, and logic level shifter by sparksfun.
logical wiring schematic
MEGA ------sparkfun logic shifter -------------ESP 8266
5V -------------HV
3.3V-----------LV
3.3V-------------------------------------------------------VCC, CH_PD,RESET
GND----------GND (both HV and LV)---------------GND
TX(#16) ------HV chn0 RX==LV chn0 RX---------RX
RX (#17) -----HV chn0 TX===chn0 TX--------------TX
the following diagram describes the wiring setup on a breadboard.
Step 2: Software Needed
Note: baudrate must match on both ends of a pair of comms device.
There are 2 serial comms as mentioned earlier.
0.0. baudrate for Serial comms between Arduino and ESP8266 Some sources on the Internet (e.g the official manufacturer's guide) recommended 57600, some forum posts recommended 115200. However the ESP8266 received (on dec14) was the latest version (0902) and the baudrate was set at 9600. Assuming all of the other parameters held correct, changing of this baudrate is not much of an issue.
The following screenshot describes the ESP8266 software version in detail following a "correct" setup on both hardware and software. The main challenge is troubleshooting uncertainty on the hardware setup and software parameters.
0.1 baudrate for serial comms between Arduino and USB monitor Assuming using hardware serial, any baudrate will do. Software serial has a limited baudrate of 19200.
0. terminal software Hyperterminal, Arduino Serial Monitor, CoolTerm, SSCOM
Assuming using the hardware & wiring identified earlier, Arduino Serial Monitor can be used to monitor the serial output. The USB port on Arduino is by default Serial0.
1. what to expect
Powering up the arduino and ESP8266 setup. The ESP8266 red led will light up, and flashes of blue LED during startup. use a wifi capable device, look for ssid ESP_XYZABC; where XYZABC is the last 6 digit of the mac address of the ESP8266. By default ESP8266 start up in soft AP mode with DHCP, and any wifi capable device can be associated to this soft AP and receive IP address of 192.168.4.XYZ
Congratulations, ESP8266 is alive (if survived any of the misfortunes happened earlier).
2. source code for testing ESP8266 with Arduino
The source code listed above merely copied data between 2 serial interfaces. Hence Serial Monitor can be used to enter AT commands via USB monitor on Serial0 to ESP8266 on Serial2.
make sure the parameters highligted in red in the screenshot are set.
from the serial monitor window, enter AT and then press "send"; assuming all parameters are set accordingly, an "OK" will be replied by ESP8266.
to reset the ESP8266, enter AT+RST and then press "send". some random data will then appear, follow by "ready"
congratulations, ESP8266 is responding to some AT commands.
3. Source code for testing ESP9266 on an Arduino with Internet
An wireless router/AP is setup with the SSID "Edge", Security is set as "WEP", and DHCP. The WAN port of this AP is connected to the Internet. In the following diagram ESP8266 is connected to the AP, and issued with a private IP. However, the WAN port on the AP does not have an IP assigned, hence there is no Internet access.
The modified source code for testing is available on gist
https://gist.github.com/teos0009/2f61b6b031a6eb35c...
Step 3: A Pat on the Back
Congratulations for coming thus far!! After all the hassle, Now, let's make some IoT inspired devices with ESP8266!!
Check out the URLs and PDF in the references section on what are the cool AT commands and configs for ESP8266
Step 4: Methodology & Observations: Setup(s) That Does Not Work/ Does Work
Official manufacturer's documentation which doesn't work out of the box for yours truly
http://www.seeedstudio.com/blog/2014/09/11/getting... a few dependencies 1. the baudrate in the blog post is 57600 whereas the ESP82665 on hand is 9600, with no mentioned or whatsoever w.r.t it in the blogpost of the manufacturer. 2. the CH_PD & RESET are not held at logic high in the blogpost of the manufacturer.
Methodology & Observations: Setup(s) that does not work/ does work
MCU: uno comm: serial0 only
code: "Examples->basic->BareMinimum"
en: 3.3v to ch_pd and REST
cct: voltage divider
baud s0: 9600
D0 rx-> tx ESP8266 D1 tx-> RX ESP8266
Serial mon on Serial0; AT and then "send" => no response
MCU: uno
comm: serial0 only
baud s0: 9600
SSCom32 on Serial0; AT and then "send" => no response
MCU: uno
comm: serial0 only
code: "serial0 setup with 9600"
baud s0: 9600
MCU: uno
comm: serial0 only
baud s0: 9600
MCU: uno
comm: serial0 only
code: "modified hello word with RGB indicator"
baud s0: 9600
Serial mon on Serial0 can't used
MCU: mega comm: serial0 only
baud s0: 9600
MCU: mega
comm: serial0 & serial2 for ESP8266
code: "copy s0<->s2"
baud s0: 115200 baud s2: 9600
D17 rx-> tx ESP8266 D16 tx-> RX ESP8266
Serial mon on Serial0; AT and then "send" => OK; AT+RST and then "send" => ready;
Step 5: Only Have an Arduino Uno?
ESP8266 on Arduino Uno with voltage divider circuit using serial0 and RGB led as indicator. Note the broken pin header on the arduino in the diagram.
modified source code is available here
https://gist.github.com/teos0009/39d602dd809fd53ed...
Step 6: ‚ÄčReferences
https://scargill.wordpress.com/2014/10/05/esp8266-working/
http://www.electrodragon.com/w/Wi07c http://blog.electrodragon.com/cloud-updating-your-wi07c-esp8266-now/ http://hackaday.io/project/3072/instructions http://tminusarduino.blogspot.sg/2014/09/experimenting-with-esp8266-5-wifi-module.html http://rancidbacon.com/files/kiwicon8/ESP8266_WiFi_Module_Quick_Start_Guide_v_1.0.4.pdf http://zeflo.com/2014/esp8266-weather-display/
3 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Oil Contest
    Oil Contest
  • Casting Contest
    Casting Contest
33 Comments
I Have an issu ,shows an error that 'Serial2' not declared in this scope.
plz someone tell me how i connect arduino UNO and Wemos D1 mini for IOT based project?
I have esp8266-01 modules from Addicore that were apparently set to 115200 baud according to the description. Does this mean I can't use them with an Uno? I looked at the modified source code for the "Step 5: Only have an Arduino Uno?" and I see it still uses SoftwareSerial, how is this possible? Is there a circuit for this code?
namasthe...
nodemcu esp8266 first time user... plz help me,
how can install my windows 7, how detect nodemcu unit... and upload my data... plz plz anyone aruino user... help me
what kind of breakout boards have you used?
This Tutorial is Perfect for me.
because esp8266 and arduino mega is only i have.
but i cant at commands doesnt work.
no response
at commands works if i send command directly to esp
like ill upload bareminimum.
ang ill go to serial monitor of arduino ide.
with baud of 115200
when i send AT
it responses OK
i really appreciate any help
pleac help me
i want code esp8266-01 using with arduino mega 2560 for control 16 chanal relay plz help
how to connect esp wifi modul with arduino mega2560
I have connected esp8266-1 to Arduino UNO and I Use 3.3 v of arduino but when i am uploading code esp shows blue light but it not accepting AT commands
I need help ive Arduino mega and esp8226 esp01 i tried it to wire them with resistor.
wifi ap mode is on but its not able to send any commands can you help me out ?
same problem here.. im using code
void setup() {
Serial2.begin(9600);
Serial.begin(115200);
void loop() {
while(Serial2.available())Serial.write(Serial2.read());
while(Serial.available())Serial2.write(Serial.read());
but still no response. i got arduino mega also converter for esp8266. can help me?
the notion is not about separating high load to low load with the use of opto isolators, but rather the difference in the logic level eg 5v from arduino and 3.3v from ESP8266. A voltage divider or logic level converter would be idea.
Optocouplers can do that also, its what they are for. https://www.fairchildsemi.com/datasheets/FO/FODM8071.pdf
For a real Arduino Newbie, would you please post a sketch of the schematic? Can't quite make out all of the connections from the photo. Great Instructable BTW!
Hi AJackOfAllTrades,
hi dee, the schematic is in the form of logical wiring. if you need the GUI-ish schematic, please follow this URL, go to the comment section and look for a contributor scott's comment.
hi jack,
look for the "schematic" under the "logical wiring schematic". not quite a schematic,but an ascii art representation; hopefully one could figure out what the wiring and connections.
